Technical Small Block Chevy 350 Rebuild
Discussion in 'The Hokey Ass Message Board' started by Firefighter1618, Mar 14, 2023.
  1. Some had a thermostat bypass
  2. I’ve ran em with the heat plugged
    If not using a PCV or booster, plug the intake hole to prevent a massive vacuum leak.
  3. gimpyshotrods
    gimpyshotrods
    That hole is left behind from the dilling of an oil passage during the finishing process.|
    There should be a plug in it.
    There exists in this diagram some extra race stuff, which you can ignore.
    427 sleeper and anthony myrick like this.
  4. Oil pressure location
    427 sleeper likes this.
  5. Since I will not have a heater, I can just put plugs in those two ports?
    PCV- do I have to have that? If I do, the PCV valve comes out of on of the valve covers and then runs to that hole?
  6. I ran a 350 for a long time with the heater ports plugged.
    You can loop them together.
    A PCV isn’t needed to run, but I ran a 350 without one and it seemed to leak much less oil after a PCV was installed.
    I prefer to have them. Just helps to have a cleaner running engine on the inside.
    My PCV is plumbed to a rear intake port commonly used for a vacuum booster
    I’ve seen em plumbed to a carb plate as well
    427 sleeper and ffr1222k like this.
  7. Anyone know what this little rod is for? It came with the short water pump.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No idea. Solid or hollow? What diameter is it? By pass block?????
  9. The one at the back of the intake, by the distributor is for vacuum. Typically used for power brake booster and it can also supply vacuum to an auto transmission. Plug it.
    The one on the front of the intake is a port to your cooling system. Typically used for heater hose. You can either plug it or install your sensor for temperature gauge.
    The two on your water pump are connected to your cooling system ... plug them.
  10. Control panel
    AAFB3F6F-0FAF-42A0-8221-ECE52AFFB490.jpeg C3FFDDC8-1C9C-4297-BFC6-15337B6173CB.jpeg AAFB3F6F-0FAF-42A0-8221-ECE52AFFB490.jpeg
    Greenblade likes this.
  11. ClayMart
    ClayMart
    For just running the engine for a short time on a test stand you wouldn't need a complete working PCV system. But at the very least you should probably have a breather of some sort in the valve cover(s) and/or a vented oil fill cap.
  12. How does the oil dipstick fit in? Is it just a pressure fit? Should it fit in all the way up to the bulge?
    Desoto291Hemi likes this.
  13. Is it OK to use 1/4” brass plugs for the block coolant drains on both sides? Can’t find black iron or galvanized here. Smallest is 3/8.
  14. Dick Stevens
    Dick Stevens
    Yes, brass plugs will be better than black iron or galvanized.
    enloe, 2OLD2FAST and Desoto291Hemi like this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    enloe and Firefighter1618 like this.
  16. Yes,,,,you drive it in,,,,,,and it stops at the swedge bulge .
    Tommy
    enloe, 2OLD2FAST and 427 sleeper like this.
  17. Budget36
    Budget36
    A tool is made to install it, kinda looks like a crows foot wrench but round inside. It fits snuggly on the tube, and the business end on the bulge. Then tap into place.
    enloe and Desoto291Hemi like this.
  18. I don't know exactly what your plan is for moving/setting up/running etc but I'd be inclined to install two petcocks so you can easily drain the coolant from the block. I am****uming you will be running straight water that gets drained after each display/running. After removing the upper and lower rad hoses, there will still be a good amount of liquid still in the block ... petcocks make draining easier.
    Just an FYI ... opening one petcock will not drain the entire block, it will only drain one side of the block.
    Algoma56 and 427 sleeper like this.
  19. I do not have the valve covers on yet. Can I dump oil directly in the hole for the distributor to fill the oil pan? Then use the old distributor I modified to work as a primer in order to see the oil coming to the top of the heads and into the valve train which is why I do not have the valve covers on yet.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
  21. Malpass
    Malpass
    i think you can just go pull one from a pick n pull for $50-$100, if my memory recalls correctly.
    ***EDIT*** This comment was incredibly late. I had only read the first few pages when I decided to comment, like an idiot.
  22. I was able to get a Holley Street Warrior 4160 600 cfm carb model 80457. Now to find the correct adapter plate. I need to go from the four hole quadrajet intake manifold to this carb Does the adapter plate need to be a four hole or one large square hole? I see they come with gaskets and hardware. 4 hole would make sense
    66AE1BFC-4B28-436A-B888-3D5B19685E9D.jpeg 87D33888-D40A-4503-A553-458D6CE75E7F.jpeg
  23. Like this: description says Holley/edelbrock to Rochester 4g 4-jet carb adapter plate
    Or like this? It says universal qudrajet car adapter, open center
    enloe likes this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    either one will work.... it does not matter
    enloe likes this.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’d use the upper one only because, we’ll things just line up better. None of this bumping in corners if there’s such a thing in a round room.
  26. I was just concerned because wouldn’t the squirters (I’m sure that’s not a technical term) have to squirt into the correct hole of the manifold?
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not really. Vacuum will send things where they need to go.
  28. carbking
    carbking
    It will work, but you will leave several ponies out in the pasture rather than bringing them into the barn.
    Better choices would be either:
    (A) a Q-Jet on your intake
    OR
    (B) your Holley on a square-bore intake
    In either case NO adapter.
    Jon
    enloe, Mark Yac, HotRodWorks and 6 others like this.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
  30. Budget36
    Budget36
    Hey Jon, why the HP loss?
    Thanks
