Everything to convert small block Chevy to dual quads.2wcfb Carter carbs w/correct casting numbers and I'd tags.Throttle linkage.All fuel lines pump to carbs,heat tube for choke.Fuel tank sending unit.2 fuel pumps one new one used.Hi dome fuel filter housing.Corvette style air filters.Mounting and air horn gaskets for carb.Intake manifold w/correct bolts.Carb studs and support for Batwing housing.2x4 engine wiring harness.Dual Point distributor.Brand new spark plug wires,ballast resistor.Figure 8 bracket for mounting coil and distributor.Deep groove pulleys for fan generator and balancer.Extra length fan belts and two brackets for mounting generator outboard.Asking $4500.00 which includes insured shipping.thanks for looking. Email mr.150@att.net Can email or text photos of everything
