Small block Chevy guys...what do I have?
Discussion in 'The Hokey Ass Message Board' started by MrModelT, Oct 15, 2012.
  1. fastlane666
    fastlane666
    Just pull off the flywheel and take a picture of the crank please. That wiil tell it all.
  2. MrModelT
    MrModelT
    Sorry guys....didn't mean to drag this out so long :(
  3. wibble_1979
    wibble_1979
    <TABLE border=1 bgColor=#cccccc><TBODY><TR><TH noWrap>3890462</TH><TH noWrap>62-68</TH><TH noWrap>1.94/1.50
    & 2.02/1.6
    </TH><TH noWrap>250-350</TH><TH noWrap>64 CC Chambers
    No bolt holes
    These are also double humps.
    </TH></TR></TBODY></TABLE>
    this is the de-coding for your heads
    <TABLE border=0 width="100%"><TBODY><TR><TD>1968</TD><TD>3970010</TD><TD>327</TD><TD>-</TD><TD>-</TD><TD>2 </TD><TD>A</TD></TR><TR><TD>1969-79</TD><TD>3970010</TD><TD>350</TD><TD>185</TD><TD>370</TD><TD>2 or 4</TD><TD>car, truck, Vette</TD></TR></TBODY></TABLE>
    and the code for the engine casting numbers.
    all this combined with the explanation on your carb it looks like you either have a 327 or a 350and the heads, block, and carb are all components used in the corvette but not necicarilly a corvette motor still a really good motor
  4. MrModelT
    MrModelT
    Will do.
  5. ArchangelKustom
    ArchangelKustom
    from NR/OH
    The 461 and 462 heads have slots with rounded ends for each pushrod, which acts as a guideplate...Unfortunately it limits p.rod diameter to 5/16".
    never knew there was a 010 327. Learn something every day.
    Model T, can you at least turn the motor over and measure the piston travel? Would be a quick way to measure stroke length.
  6. MrModelT
    MrModelT
    I have no problem measuring the stroke for those who are curious..or just for peace of mind, but I'm okay with leaving this as an understood 350.
    This is why I am relying on you guys to tell me what this thing is, and I trust your judgement.
  7. Deuces
    Deuces
    I say it's an 11:1 with the 65cc heads...
  8. sunbeam
    sunbeam
    all 350s were large journal in 67 the 350 was the only small block with large journals.
    Uncle Lee likes this.
  9. cavistyle
    cavistyle
    from baltimore
    350 with double hump heads. Prob a strong little motor.
  10. 32Tudor396
    32Tudor396
    After reading thru this whole thing,I thought I'd let you know I hauled on of those bottom ends away this summer.....got tired of looking at it!4 bolt too.....The neighbor is a chevy guy and he didn't want it either!
  11. falcongeorge
    falcongeorge
    from BC
    Me either, but then you and I just arent romantics. Such is the stuff that endless bench racing sessions/******** fests are made of...:rolleyes:
  12. dirty old man
    dirty old man
    Then you and your neighbor both apparently have no sense of value!
  13. Definitely not a Chevy Fan, but I think you are a fool to s**** that, if indeed you did (my BS meter is flashing here). If you can't sell off a 350 chevy 4 bolt and make more than s**** rate on it, there is something wrong.
    I would have given you s**** rate on it and resold it myself!
  14. Desert1957
    Desert1957
    from Pa/Md
    Did anyone notice the front engine mount? looks like 55-57 Chevy style.
    "010" blocks are good old stuff from GM , No way of knowing which crank it has without taking the pan off. GM only made 1 year of large journal 327 cranks and it wasn't steel.
    Desert
  15. 32Tudor396
    32Tudor396
    And the crank rang like a bell....
  16. Model T1
    Model T1
    MrModelT, you don't need to appologize for this thread going into overtime. It's us who are continually adding our words of wisdom (?) And those of you complaining it has, stop writing comments and it won't be so long!:D
    I still think it's a neat old Ford orange engine!:rolleyes:
    MrModelT likes this.
  17. Sal Cicala
    Sal Cicala
    Slight correction on the carb. It is actually about 600 CFM and not 650, and was for '66 Corvette only with a 327/350 HP engine. Chevrolet never put a Holley on the 327/300 HP engine. To me the carb is probaly worth at least about $500 in it's current good original condition, minus the damage someone did by drilling a hole in and grinding on the air cleaner ring. Plus it looks like there was a phillips head screw in it to hold something on. Too bad for that part.
  18. MrModelT
    MrModelT
    Good info Sal. I noticed that work too, not sure what the reason for it was either. :confused:
    Thanks T1. Very true, but still....I should have had some better info by now for the guys that need it. Just hard to get over there and tear into that thing with a family and other "irons in the fire". For my "not so timely-ness" I apologize :)
  19. ArchangelKustom
    ArchangelKustom
    from NR/OH
    Have never seen heads stamped left and right either. Someone definitely put some effort into it.
    Someone needs to drop that into a 55 2dr post with a 4.11 and close ration trans :)
  20. Deuces
    Deuces
    Someone on here has a GM LG 327 steel crank...
    1969 was the last year of the 327...
    LG 327 cranks were made in '68 and '69....
    And let's not forget all the 307 crankshafts... From '68-'72???
  21. falcongeorge
    falcongeorge
    from BC
    That would be me, for one. I was actually going to go out in the shed and take a photo of it tonight, and post it. Whew! Thank god for the "wisdom" on the HAMB! I almost built a motor around an imaginary crank!:eek::rolleyes:
    And yes, '68 and '69 is correct. Boy, if Gene thought there was a lot of ******** on that FE thread, he should come take a look at THIS mess!
  22. tjet
    tjet
    FYI, cast cranks "ring" better than forged cranks do.
  23. henryj1951
    henryj1951
    from USA
    so we'll never know
  24. brian55lvr
    brian55lvr
    from ma
  25. 202 heads...327 or 350...casting number was same....could even be 302 chev...bore and stroke will tell you...nice little motor with possiblity.....get rid of holly...!!!....
  26. MrModelT
    MrModelT
    Hey guys, sorry for not having a new update in a awhile, just haven't had the time to get the pan off and look at the inards. I plan to do so soon...as well as get the bore and stroke measured up.
    Sent from Mr. ModelT's DROID device using the TJJ mobile app
  27. Deuces
    Deuces
    It's been a few months... So, what's the word on it???
  28. HamD
    HamD
    If the piston markings match the info someone found earlier in the thread, it's a
    fire breathing SOB that can make even you and me read the WHOLE thread.
    Well, almost.
  29. Branden
    Branden
    Hello all I need help I got a motor sitting in my garage from my recently past away father in-law I know its a chevy small block but I cant figure out what it is the casting numbers are 18GM 3970010
    Deuces likes this.
  30. Deuces
    Deuces
    Sounds like a 350...
    Looks like you have a pair of angle plug heads also.... You need to take off a valve cover and snap a picture of the 7 digit casting numbers on the head then post it on here... Thanks!
