small block Chevy Q
Discussion in 'The Hokey Ass Message Board' started by Mooseandsqurl53, Sep 20, 2012.
  1. Mooseandsqurl53
    Mooseandsqurl53
    from N.J.
    A friend of mine has a small block apart and was asking me what all the numbers cast into the front of the block inside the timing cover mean. Can anyone enlighten us? If you need a pic, I'll try to get one and post it. Thanks.
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Those probably mean something to the people who cast the blocks and distribute them, but not a lot that I know of to the rest of us. The only numbers that really matter for identification purposes are the ones on the back of the block and by the p***enger side head on that pad.
    Those numbers in the timing cover area could be dates and shifts that the casting was done, or something similar.
    Don
  3. i'm sure there was more than one pattern to cast the blocks....so it could be a pattern number , in case there is a problem and they have to go fix it.
  4. squirrel
    As far as I can tell, they use some of the patterns to make the molds for several different blocks, so you'll see the last three digits of the block casting numbers that were made with that pattern. For example, you might see 010 020 509 on a block that uses an pattern that makes the 350, 307, and 400 cubic inch blocks.
    this relates to the old wives tale that those numbers are somehow related to the alloy of the block...but that does not make any sense, if you look at all the blocks and figure out that the numbers are indeed the last 3 digits of block casting numbers.
  5. DAVEO!
    DAVEO!
    it tells more about what kinda car it came in what ****** it had ect ect
  6. squirrel
    That number/letter sequence is stamped on the top of the block, not cast into the timing cover area.
  7. Don's Hot Rods
    Don's Hot Rods
    from florida
    It's probably like the Mayan calendar thing. A couple of bored GM employees just put those numbers inside there to make us scratch our heads some day. :D
    Don
  8. squirrel
    Did you ever notice the same thing with the P*** TRUCK HI PERF on big blocks?
  9. BOBCRMAN
    BOBCRMAN
    from Holly
  10. squirrel
    These are probably the numbers he's talking about. The three digit numbers are all the last three digits of known block casting numbers, such as 3970010 etc
  11. Mooseandsqurl53
    Mooseandsqurl53
    from N.J.
    Thanks for the info, guys. Squirrel, the pic is exactly what we were asking about.
  12. bustingear
    bustingear
    Let's try to keep the wives out of the garage. We don't want them drinking all ofthe beer stash out there!
