Small Block Chevy with Wescott Stock Firewall
Discussion in 'The Hokey Ass Message Board' started by GonzoMN, Jun 10, 2013.
  1. GonzoMN
    GonzoMN
    Will it work or will I need to modify the firewall?
    Anyone done this?
  2. Pewsplace
    Pewsplace
    It will work with the stock firewall. I have done two of them. The fan is close to the radiator but clears. A stock Deuce firewall in an original car does not need to be cut either so the Wescott works. Depending on your transmission you may need to trim the lower toe board section for clearance.
  3. GonzoMN
    GonzoMN
    Thanks much, just what I was looking for.
  4. cartman4gc
    cartman4gc
    I've also done both original '32 and Wescott bodies and didn't have to cut anything.
    Short water pump and single pulleys. Also, use a Zips water pump riser and you don't have to fool with and electric fan.
  5. HOTRODPRIMER
    HOTRODPRIMER
    This is exactly what I would have said. HRP
  6. GonzoMN
    GonzoMN
