Small Block Ford Victor Jr Heads
Discussion in 'Off Topic Hot Rods & Customs' started by AldeanFan, May 5, 2025.
  1. AldeanFan
    AldeanFan
    Has anyone built a 302 based engine using Edelbrock Victor Jr cylinder heads?
    I came upon a set of heads that were too good of a deal to p*** up. I can either build an engine around these heads or p*** these on and maybe make a few bucks profit.
    Edelbrock Victor Jr 77169
    60cc chamber, 201cc intake runner, 2.05/1.60 valves.
    I have several 302 powered cars so if I use these I’d like to stick with a 302 block, probably stroked to 347. Looking for a somewhat streetable engine.
    My experience with ford engines is on mostly stock bottom ends and all my friends run Chevy engines.
    if you’ve built an engine with these heads please share the combination and results.
  2. MAD MIKE
    MAD MIKE
    from 94577
    Those heads are more at home on a big bore engine, 2.05" valve oof... screamer engines. You can make them work on a modified 302 28oz or 0oz 302.
    Dont slap them on a stock block 50oz imbalace 5.0 and expect it to last.
    porkshop likes this.
  3. AldeanFan
    AldeanFan
    Thanks,
    I’m still trying to decide if I use them or trade withs someone building a big inch small block.
  4. Deuces
    Deuces
    Those would be nice on big Windsor also.... I have a set of Trick-Flows on mine.... The Twisted Wedge type....:cool:
  5. AldeanFan
    AldeanFan
    I had plans to build a 331 with a stock 302 block and AFR heads. I currently have two cars with 302’s so that would be a bolt in and I could keep all the front dress, headers etc.
    These Victor Jr heads were too good a deal to p*** up so now I’m tempted to build a 408 Windsor for something.
    Deuces and ffr1222k like this.
  6. Deuces
    Deuces
    You might want to start off with a roller block....;)
  7. AldeanFan
    AldeanFan
    After seeing all the cams my friends have ruined on breakin I only build roller cam engines now
    Deuces likes this.
  8. 6sally6
    6sally6
    2.05/1.60 valved heads 'will work' on a 331/347 SBF BUT......you need to gear accordingly.
    (Think like all 'these guyz' with their 327 SB Shivel-laz they just LOVE to hear that baby
    " whine-in-the-upstairs-of-RPM-ville"! )
    Think in the 6000+ RPM range ! Like a BOSS 302... (minimum)
    4.11:1 gear MINIMUM . 4.30:1 on the street with a re-done T-5 so you can actually afford the hi-test fuel it's gonna need ! (using the OD 5th gear)
    Make sure the rods are premo units as well as the roller valve train. Think light-weight everything in the valve-train.
    Single-plane intake with 750 cfm Eddy carb. (cause I like 'em...that's why!)
    4-tube full-length headers or better yet the 'bundle-of-snakes 360* headers...
    See where I'm going here?
    IF you wanna "hear-that-baby-sing-on-the-top-end" it's gonna be expensive 'singing-lessons' !!
    Post us a video !!!!
    6sally6
  9. AldeanFan
    AldeanFan
    If I build this engine it will likely be in my factory five cobra screaming through the Sidepipes on the road course and drag strip.
    Deuces likes this.
  10. 6sally6
    6sally6
    A FINE place for it ^^^^^^^^^^^^^!!!
    6sally6
    Deuces likes this.
