Small Block or NOT?
Discussion in 'The Hokey Ass Message Board' started by Clik, Feb 24, 2010.
  1. No,you can't say that for hemis,dodge gave up on those 50 years ago.
  2. Clik
    Clik
    I guess it's going to depend on my timeline and if I am able to find a donor car.
    The SBC is so practicle but I don't want something so common in such an uncommon car.
    A SB Ford isn't as common but I don't need the droopy pants Mustang boys loitering around my ride.
    If the big block Olds is as light as some of you guys are telling me I'd go that way if I could find one at a reasonable price.
  3. Left Turn
    Left Turn
    from Omaha, NE
    Just keep yours eyes peeled for big Olds 88's and 98's, or Toronados.... A 425/455 would be so sweet.. A 400 would be too if you could find one..
    And if you want to go early olds a 394 would be ***s... I've got one sitting on the shelf that I'd love to use in a Falcon or a Chevy II, or an altered A Pick Up...
  4. Bigcheese327
    Bigcheese327
    +1. The Pontiac seems to be the forgotten nostalgia motor.
    -Dave
  5. farmer12
    farmer12
    Go for a Hemi! sbc is ok, just keep the hood closed.........
  6. Left Turn
    Left Turn
    from Omaha, NE
    If you think the SBC dethroned the flathead ford you sir need to go take a second look at your history books... The last year for the Flatty was '53 the Y came out in '54.... And I'm going to go out on another limb here and say that if it wasn't for the early Rockets that SBC wouldn't be here, reason being the Olds and Cad mills were the first OHV V8's.....
  7. 3x2rocket
    3x2rocket
    Clik, 455's do weigh about the same as sbc, I read an article in car craft mag (I think) about an Olds 455 they had built and with aluminum intake and heads it weighed significantly less than a stock sbc, also made more power than their dyno was capable of measuring... more than 600 lbs-ft...
    It may not be traditional, but still carries the name "Rocket" at least...
  8. Clik
    Clik
    I was really intrigued by the 455 and its reported light weight, even though it's a little past the era I was aiming for. I haven't exactly been tripping over them either. Donor cars seem rare as well. Now I have another dilema: My die hard bow-tie buddies are giving me the plague as well by donating freebies to the cause. One of 'em just dumped a four-bolt-main SBC on me just to keep me in the family. It's hard to argue with free. Maybe I can put a different intake on it or somethin' to make it not so common.
  9. BEAR
    BEAR
  10. Bigcheese327
    Bigcheese327
    Stick a large-journal 327 crank in it.
    -Dave
  11. I notice the Ford small block is not the obvious choice that I thought it would be after the chev.I,m going Ford S.B.,mostly on the belly ****on syndrome but whats not been mentioned,they just got a better growl; a must for street poseurs :D
  12. teddyp
    teddyp
    after reading this whole thread sbc is the only way to go most of the motors that are mention in here were all pulled out and replaced with sbc,s in the time frame you want but if you want the new fake old school look then any of these choices would be good it all comes to what you like it,s your car the only boreing thing is the those who try to tell you what you must have in YOUR CAR just my 2 cents just have fun with what ever your choice you make
  13. Slow55
    Slow55
    If you get tired if the Small Block Chevy, there is ALWAYS someone that will buy it from you.
  14. 1oldrat
    1oldrat
    66-67 400 olds motors work great.Maybe a 60'2 425 olds.They had a **** load of torque.I have a 70 455 from a toronado and it is rated at 370 hp with 500 ft lbs of torque from the factory?
  15. Clik
    Clik
    I've got a 324 in the garage. Unfortunately it's in the ol'lady's 56 Olds and she ain't givin' it up.
    The SBC is getting magna this week. If it checks out I'll stroke it with a new crank.
  16. Bigcheese327
    Bigcheese327
    I suppose it's too late to persuade you to go with a hot rodded Henry J engine (Continental flathead)? That would really screw with some people's heads.
    -Dave
  17. fifTsix
    fifTsix
    from TEXAS
    just do what YOU want for crying out loud
  18. Clik
    Clik
    Ive got the HJ's Supersonic Six but even if I doubled the horsepower I'd still be well below two hundred.
  19. twofosho
    twofosho
    Mura bros seemed to think a big block Mopar was the hot setup for a Willys g***er in 1964, so did a lot of other people that saw theirs.
    Big block Mopar wedge came out in 1958 and thanks to all the high performance bits offered by the factory (multi carb intakes, ram tuning, etc.) leading up to the Max wedge motors, within the first five years, unless factored out by cl*** restrictions, became the motor to beat until the advent of the second generation Hemi. Fuel injected Sting Rays or not, if you were herding a built big block Mopar on the street in the early sixties, small block Chevrolets didn't give you much worry.
    Find a 400 block, stuff in a 440 crank to gain more than a little cubic inches in the low deck rigid block, pop on a cl***ic 2X4 cross ram, build a righteous set of fenderwell headers, back it up with a push****on 727 and Dana 60, and stir into the mix the Willys body style of your choice.
    What's not to like?
  20. Clik
    Clik
    What's not to like you say? Weight.
    I am a Mopar fan though. Keeping my eye open for a barn find 69 Dart GTS that some ol' farmer will let go for a hundred bucks and a sack of corn.
  21. hotrod32@usfamily.net
    from st paul
    small block ..no come on I know easy and cheap but geez is goin to be a rat rod or what!!!!!
  22. 56oldsDarrin
    56oldsDarrin
    I would probably qualify as a SBC hater, (big Olds guy) But a revvy little 327 seems natural to me, someone earlier mentioned thats what he usually saw in the 60s, thats good enough for me.
    Crusty tunnel ram?... finned valve covers with big racy breathers?... Old school cam!
    And its a natural for the 4.10s
    383s are good for lugging, not revving.
  23. Clik
    Clik
    I just ordered a set of Firestone pie crust cheaters in 16" which I'm guessing would bring the 4:10 gears down to about 3:90? The tunnel ram and finned valve covers will be a must. Fenderwell headers to bottom things off. I'm not sure what I'll put on the end of them.
  24. RamblerClassic
    RamblerClassic
    Want an Unusual motor?
    455 Olds
    287 Rambler
    421 Pontiac
    500 Caddy
    572 Chevrolet (Pricy but big)
    Or if you are too into chevy's just get a 327.
  25. 55 gasser pickup
    55 gasser pickup
    from utah
    i say if high rpms is what you want a high winding 327 with a tunnel ram is always cool
  26. 55 gasser pickup
    55 gasser pickup
    from utah
    unless it has those ugly cheap edelbrock carbs on it then its thumbs down.for me anyway
  27. 73RR
    73RR
    The extra 100 lbs disappears when you have 500 ft-lbs of torque....
  28. willowbilly3
    willowbilly3
    from Sturgis
    Exactly what I was thinking. Just about any 50s V8 will weigh more than a SBC. I like Olds engines, always had good luck with them. Rebuild parts are expensive though. This is way outside the box but something like a 289 Stude or a 327 Rambler would be cool as hell. But then I like unique stuff and ain't out to win races. I always figure a unique rod shouldn't have a boring belly ****on engine, even if it is the cheapest thing around.
  29. interst8er
    interst8er
    from SoCal
  30. kingpins
    kingpins
    got my vote also. nice nice motors!
