Small fuel filter
Discussion in 'The Hokey Ass Message Board' started by need louvers ?, Aug 21, 2011.
  1. need louvers ?
    need louvers ?
    Hey gang!
    I hit the search for this but couldn't find quite what I'm looking for. I'm out bending up some pretty fuel lines for the girlfriends falcon wagon, and my thoughts turned to fuel filters. What I need is small preferably steel filter that has female 5/16" inverted flare ends. I know that G.M. used something to this effect at some point or another, but I need a part number or at least close on an application. Any body have any ideas?
    This is going on a way mild 200 c.i. Ford six, so I don't need any thing too exotic.
    Thanks, Chip
  2. Deuce Roadster
    Deuce Roadster
    I forget the number but is was something like GF - 62 ... IF I remember correctly.
  3. GF62C was my favorite. It has since been since discontinued. Socal even sold it for a long time. Makes me sad. When I sell the 54 I may just hold onto mine.
  4. need louvers ?
    need louvers ?
    Cool Duece...
    I wouldn't mind knowing the brand on that one for another project, but I should have been a bit more specific. I need something small (like about 1 1/2" or 2" diameter) that I can plumb into my line to the carb. Thank you very much though!
  5. That one is an AC Delco GF62c^^^^^^^^^^^^^^If I could find them I would buy 4
  6. need louvers ?
    need louvers ?
    Let me check my little old real parts store here in town tomorrow, They always seem to have older stuff on the shelf. If I'm lucky, we'll figure out how to get one to you...
  7. dmc3113
    dmc3113
    Sometimes you can find those GF-62C Delco filter kits on eBay. The last time I saw one there I think it went for around $50.00. I should have stocked up on those when I was a AC-Delco salesman. They were about $20.00 jobber price. I don't know if the elements are still available or not. I think GF-58 is the correct part number on the element.
  8. Deuce Roadster
    Deuce Roadster
    The element is still available. I bought 6 about 3/4 weeks ago at my local Chevrolet dealer. He ordered them and it took 3 or 4 days ... but he got them.
  9. Thanks, I will buy all they have!
    Cool, I knew they were available but I want to stock up!
  10. seb fontana
    seb fontana
    from ct
    Napa 3481 would be close...Has 1/4 pipe at each end but once they get there they should be able to find one with the 5/16 inverted flare ends, probably can see it in napa.com...
  11. Toner283
    Toner283
    This one is not steel but it is a small one & the filter element is readily available. AC Delco filter P/N GF 48. This filter was used on all kinds of applications. I have seen them listed for late 40's/early 50's Caddy's and also for tri power big block Corvette's. These are also reproduced and the packaging reads "reproduced using original GM tooling" the box in the pics is about 4 inches square.
  12. need louvers ?
    need louvers ?
