1952-59 Ford Small problem
Discussion in 'Off Topic Hot Rods & Customs' started by 54HotRod, Nov 19, 2011.
  1. 54HotRod
    54HotRod
    Apparently when I took the steering gear out of the car last summer, I didn't take as many pictures as needed. As I was putting the column back together, I realized that there are only two pictures of how it looks together and none during dis***embly. If you have any pictures that may help I would love to see them. Thanks for your time.
    Steve
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Send rustyfords a pm I think He has pictures of His step by step.
  3. 54HotRod
    54HotRod
  4. 54HotRod
    54HotRod
    I contacted rustyfords, but I have yet to receive a response. If anyone else has pictures or can just walk me through how to put the turn signals back together and everything else that goes under the steering wheel, I would greatly appreciate the effort. I have the steering box mounted back in and the column back together minus the above mentioned items.
  5. 54HotRod
    54HotRod
    Problem solved! I sat in front of the steering column and tinkered around with all the pieces until I figured it out. Then I took it all apart and put it back together taking pictures through the whole process. If anyone needs pictures for this type of thing, I now have them.
  6. Crazy Legs
    Crazy Legs
    Glad to hear you got it figured out! - Check PM
  7. 54HotRod
    54HotRod
    If anyone else needs the pictures or information of how to do this, PM me with your email address and I will send you all the information you will need.
