Smallest 12V Battery????
Discussion in 'The Hokey Ass Message Board' started by dsiddons, Dec 3, 2012.
  1. dsiddons
    dsiddons
    from Indiana
    I'm in need for the smallest battery possible due to space. Any suggestions? Flathead with bare mins... Thanks
  2. Von MoPar
    Von MoPar
    from Australia
  3. dsiddons
    dsiddons
    from Indiana
    That did. Thanks
  4. S_Mazza
    S_Mazza
    A motorcycle battery might work ... but it depends on stuff like the compression of the engine, do you use the car in winter, etc. Starting on a cold day should be the hardest test, I believe.
  5. 2935ford
    2935ford
    I just picked up an Odyssey PC925...fits between my '32 frame rails.
  6. junkyardjeff
    junkyardjeff
    I have a couple Honda Civic batteries in my rides,they are small and have the power to start a V8.
  7. ibuild
    ibuild
    i tried small and didn't like it so now i buy big and good cables, my cars crank, never liked the idea of stopping and a few minutes later the car not wanting to start
  8. rramjet
    rramjet
    Got an Odyssey in my 32 that's the smallest I've ever seen.
  9. Tommy's Cycle
    Tommy's Cycle
    from So Cal
    Check out the Braille AGM batts.
  10. A Boner
    A Boner
    Sportster battery works good with my mild sbc.
  11. Fogger
    Fogger
    2nd on the Odyssey PC925, I used the MJ model which is metal jacketed and easily fits in a modified '32 Ford battery tray. The metal jacket protects the plastic case from impact and keeps the case from swelling from heat.
  12. dsiddons
    dsiddons
    from Indiana
    I bought the Odyssey. It appears to be about the size of a cigar box.
  13. IronTrap
    IronTrap
    If you want to save some bucks Deka makes a lot of those small dry cell batteries for Braille and the like, can be had directly from a deka dealer if you know the specs you want.
  14. bobscogin
    bobscogin
    That's the battery to use.
    Bob
  15. flatheadpete
    flatheadpete
    from Burton, MI
    I used an Interstate lawn tractor battery in the Peter Beater for years.
  16. They will certainly turn a V8 over but the engine needs to be a good starter because they won't do it many times before they quit. If you don't use the car every day it's best to have an electric fuel pump because a PC925 will not like turning the engine over so the mechanical pump can fill the fuel bowl.
    I'm not saying don't use a PC925 - just pointing out that you make some compromises when you use a battery that small.
  17. 30dodge
    30dodge
    from Pahrump nv
    Why not run longer / thicker cables ?
    Back in the 60s we would put the battery in the back were we could get to it easy
  18. dsiddons
    dsiddons
    from Indiana
    Got a rumble seat back there.. Probably mount it on it's side below the p***enger floor board.
  19. Also remember that you can run two 12 volt batteries in parallel if the first one doesn't provide enough power.
    Charlie Stephens
