Technical Smith-Jiggers OHV Flathead
Discussion in 'The Hokey Ass Message Board' started by El Caballo, May 29, 2025.
  1. El Caballo
    El Caballo
    from Houston TX
    Most bonkers thing I’ve ever seen on a flathead.
    NoSurf, RMcCulley, Sharpone and 7 others like this.
  2. CSPIDY
    CSPIDY
    looks like they converted it into an F head
    and
    What kind of contraption is that distributor?
  3. alchemy
    alchemy
    Yes, intake uses stock valves but exhaust is now through the head. Magneto on the front is exactly like the one that Ryan had stolen.
    seb fontana, SS327, Sharpone and 2 others like this.
  4. winduptoy
    winduptoy
    Yes, it is an F head conversion...way cool if it was in someones car having the snot driven out of it
    NoSurf and Sharpone like this.
  5. 302GMC
    302GMC
    from Idaho
    Jiggler, not jiggers ....
  6. J. A. Miller
    J. A. Miller
    from Central NY
  7. BJR
    BJR
    I wonder if anyone knows how much of a HP increase you get with this conversion? Or is it just like putting chrome valve covers on an OHV engine.
  8. Sharpone
    Sharpone
    Very cool
    Dan
  9. Toms Dogs
    Toms Dogs
    from NJ
    Speccie likes this.
  10. s.e.charles
    s.e.charles
    so .... were these types of heads ever made for a full size flathead?
    my search gave me 30 hits of "60" reference and most of them only single word references from 20 years ago.
    thanks
    sid
    Sharpone likes this.
  11. Ryan
    Ryan
    ADMINISTRATOR
    Man… That is a gorgeous motor…
  12. drtrcrV-8
    drtrcrV-8
    A long-gone racer-friend reported that he drove a V8-60 with a set of these, & while they didn't add that much HP, they allowed a lot more RPM.
  13. Dave G in Gansevoort
    from Upstate NY
    And cooled better. Got the exhaust out of the block, and if you look closely at the head it doesn’t have any water around the exhaust.
  14. s.e.charles
    s.e.charles
    c'mon guys. i had the courage to necromance this thread, somebody at least take a guess to make me feel wanted . . . .
  15. seb fontana
    seb fontana
    from ct
    Not to my knowledge.
  16. tubman
    tubman
    Several vendors made "F" head conversions for full size flatheads (I believe Riley and Tornado were a**** them,) but they were actually quite different in configuration that these.
  17. drtrcrV-8
    drtrcrV-8
    A further note : that racer friend said that the screws on the rocker covers had to be safety wired or they would vibrate out due to engine harmonics... This was in the early/mid 1950s
  18. Ned Ludd
    Ned Ludd
    EOI engines are unusual. I'm not aware of any which aren't converted side-valve engines. IOE is common enough e.g. the Willys Hurricane etc. The most interesting one is probably Rover's, which featured a angled deck like on a Chevy W-engine.
    The pic doesn't show the spark plug location on that Flathead. Engines like the Rover work well because the intake valve is over the quench area, and the hot exhaust valve is at the bottom of the combustion chamber with the spark plug close to it. Having the exhaust valve over the quench area is less than ideal. The only way to do that would be with a relatively low CR and a longish bathtub-shaped chamber, with the plug on the outboard side of the exhaust valve. That wants forced induction?
