Technical Smoking Av8
Discussion in 'Traditional Hot Rods' started by Henry the Ford, Aug 29, 2023.
  1. Henry the Ford
    Henry the Ford
    Hey All
    I’m new to the board and to flatheads. Been a long time coming!
    I have a ‘28 coupe, A frame.
    ‘39 top loader, open drive shaft and a ‘51 f1 rear end.
    ‘46 59ab with sharp heads and intake with dual Stroms.
    I’m getting a pretty fair amount of smoke out of the breather. Is this something expected or an indication of a problem?
  2. dwollam
    dwollam
    Tired, like my avatar. Your pics didn't show up.
    Dave
  3. 327Eric
    327Eric
    You pictures are not loading
  4. Bandit Billy
    Bandit Billy
    Blow by. Add a PCV to **** the crankcase vapors and the breather will become an inlet rather than an exhaust pipe.
    Flathead Dave likes this.
  5. If a Flathead isn't huffin a little Blow By it isn't running. Don't worry about it, keep building.
    Outback likes this.
  6. winduptoy
    winduptoy
    don't let it idle....put your foot in deep
    Outback likes this.
  7. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    It needs a good ring and valve job. Period.
  8. Henry the Ford
    Henry the Ford
    Thanks for the feedback!
    I will work on the photo posting issues.
  9. Henry the Ford
    Henry the Ford
  10. ERguitar
    ERguitar
    You are going to get responses from "it's normal" to "prepare yourself for immenent engine failure". What is your oil consumption?
  11. Henry the Ford
    Henry the Ford
  12. ERguitar
    ERguitar
    No pics . But if it isn't eating oil I would tend to agree with those advising a pcv
  13. Henry the Ford
    Henry the Ford
    Thank you!
    The charm of the smoke and smell is hard to beat. Just looking to make sure it’s not unusual.
    this is my first flat 8. Have had several 4s and knew what was expected.
    I can see the photos I post. I’ll do some reading.
    Thank you again.
  14. Henry the Ford
    Henry the Ford
  15. trevorsworth
    trevorsworth
    Never seen one that didn't have a little blowby. The PCV valve recommended by Billy is a big benefit to the engine's long term health. Most will burn a little oil too. No sweat... just drive the hell out of it and keep the oil fresh and at the full mark.
  16. Henry the Ford
    Henry the Ford
  17. Henry the Ford
    Henry the Ford
    Good morning Hambers!
    Hotrodmyk and osage orange like this.
  18. Zax
    Zax
    Yep, pics work now.
    Run a compression test on it. That will tell you more about the condition of the old flathead.
  19. Flathead Dave
    Flathead Dave
    from So. Cal.
    There are books.
    Try a PCV. Easy and cheap. About $40 to $50.
  20. Henry the Ford
    Henry the Ford
    I have Mike Bishops and Vern Tardell’s
