Technical Smoothin’ an engine block
Discussion in 'The Hokey Ass Message Board' started by Heavenly Hearse, Jun 16, 2022.
  1. Heavenly Hearse
    Heavenly Hearse
    Hey fellas,
    I’m looking to smooth out casting marks and such from a 472 that is going in my T. I know some of ya’ll have done it and wonder if you’d share pictures or tips.
  2. 41rodderz
    41rodderz
    from Oregon
    Any casting flash just die ground near flush then try 80 grit (60,40) whatever you have and keep going finer to your liking. If it isn’t tore down for a rebuild just make sure you cover any openings.
    dana barlow, LWEL9226 and VANDENPLAS like this.
  3. NoelC
    NoelC
    Being a fan of smooth... grinder, flap discs, carbide bits get the job done. IMG_3646.JPG
    Hank37, Deuces, 2Blue2 and 1 other person like this.
  4. Hillbilly Werewolf
    Hillbilly Werewolf
    What is generally done with the cast in part numbers? Leave them for identification, or just grind it all smooth?
  5. dreracecar
    dreracecar
    from so-cal
    Better to leave the serial numbers on the block just incase you get pulled over or in some states to get it registered. Spent a lot of hours pealing and smoothing the block on the race car because it looked cool, engine didnt last a season.
    Blues4U likes this.
  6. ekimneirbo
    ekimneirbo
    Yes :p
    firstinsteele likes this.
  7. gimpyshotrods
    gimpyshotrods
    Flap discs, both on a hand grinder, and an smaller air one. Safety goggles, and respiratory protection.
    I would not ever do this on an engine that is together.
    I send the block and heads (and any other parts to be smoothed) out for mag check first. If no cracks are found, I will do all of the smoothing before any machine work or ***embly is done.
  8. In Ontario Canada the Ministry of the Environment use casting numbers/stampings (of the block) to determine which emission controls the engine was born with. If the Ministry of the Environment guys can't determine the year of your smooth 1969 350 SBC, then they have the power to/can/will date it as the latest a 350 had two-piece rear seal and drivers side dipstick. Technically speaking, they could date your engine as a 1979 and require the emission controls that a 1979 350 came with even if it's actually original to your 1969 vehicle, simply because the identifying numbers have been removed.
  9. poco
    poco
    from oklahoma
    Did it one time, will never do it again. To much work for not much better looks. Also engine ran a little warmer.
    jimmy six likes this.
  10. Weedburner
    Weedburner
    from Wa State
    I removed side mounts and fuel pump boss while lightening up this sbc, cutoff wheel in a angle grinder, carbide in a die grinder, and a flap wheel...
    Grant
    mgtstumpy, winr and VANDENPLAS like this.
  11. lcfman
    lcfman
    from tn
    Get ready for a lot of work. I have done it.
    jimmy six, bobss396 and VANDENPLAS like this.
  12. ahshoe
    ahshoe
    I’ve used these for detail sanding.
    Fun fun.
    Just do it before ***embly.
    I usually epoxy blocks and heads before I ***emble them when I get em back from the machine shop. That way the oil doesn’t get into the pores. The epoxy is easier to clean.
    I’ll use a cleaner with s scuff pad to clean and sand the epoxy. Then use a 2 part automotive or industrial paint.
  14. Rickybop
    Rickybop
    As said... lots of work.
    Don't even start unless you're committed to finishing. Cuz there's no way to put back the texture if you stop part way through. And you end up with a partly smooth partly rough engine.
    You're going to go through a lot of spiral rolls and such.
    You can either go completely crazy and smooth every inch of metal. Or you can just go half crazy, knock all the high nibs off that always show through the paint and depend more on the primer to fill in a lot of the low spots.
    And of course use a good two-part paint for durability.
    Just Gary and 427 sleeper like this.
  15. 427 sleeper
    427 sleeper
    OR... just leave it as cast and paint the S.O.B! If you want it THAT smooth, It should be Chromed! JMO...
    Grimpala, mrspeedyt and Rickybop like this.
  16. Roothawg
    Roothawg
    I polish every single motor I build. I love the look.
    BB2F108D-DA23-4BD7-B42F-DD85C85EFFAE.jpeg C400C402-1E81-49BB-BBCC-EECE5B14F062.jpeg Never seen a degrees difference in cooling capacity.
    It’s worth it to me to not have the sharp casting flash cutting my hands.
    I say do it.
    alfin32, kadillackid, 2Blue2 and 3 others like this.
  17. drtrcrV-8
    drtrcrV-8
    The sprintcar guys used to go a bit overboard to get rid of some weight especially when the aluminum blocks showed up(They were WAY expensive). I have an old "Bowtie" block that originally weighed about 180 to 185lbs, & the guy I bought it from had "lightened" it down to 152lbs! He said it was to compete with the aluminum blocks when they were too broke to buy one. They ran it one season, then got a sponsor to spring for an Aluminum block! It is an exercise in metal removal, & now the only thing it's good for is a sprintcar because they removed the fuel pump & oil filter bosses, & almost anything else that would allow you to use a conventional motor mount. Sure is pretty, in a "minimalist" sort of way...
  18. Rickybop
    Rickybop
    Block sanding is a *****. LOL
  19. goldmountain
    goldmountain
    Since you are building a T with a polished Cad engine, look up an old thread here posted by Langy on his T coupe build. The car didn't get finished because Langy died, but his build skills were amazing.
  20. Ned Ludd
    Ned Ludd
    This interests me mainly for the possibilities for getting rid of the characteristic look of modern engine castings, especially that waffle pattern, when fitting out a modern engine with traditional tech. Is there a way to add back a sand-cast surface finish?
    tomkelly88 likes this.
  21. buzz4041
    buzz4041
    from Texas
    As stated be prepared to spend a lot of time. Have an ****nal of rolocs, carbide burs and flapper disc. Have fun. Engine4.jpg
    VANDENPLAS likes this.
  22. bobss396
    bobss396
    I did my ram horns exhaust manifolds. The new Dorman I bought had all sorts of risers, flash and lettering on it. I used an industrial band saw to remove the biggest nubs and a big belt sander to do the rest. It was worth it and I painted them with POR15 manifold paint.
    Algoma56 likes this.
  23. mrspeedyt
    mrspeedyt
    Can't see the point of all the work. Just paint it. I guess I'm just lazy.
    BamaMav, Deuces, ffr1222k and 5 others like this.
  24. chopolds
    chopolds
    from howell, nj
  25. 48stude
    48stude
    I ground my 327 mainly with 2" roloc style disc
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I smooth castings for several reasons:
    - removing all the flashing reduces the possibility of crack formation
    - removing / chamfering sharp edges and corners may save you a skinned knuckle
    - it is easier to keep the engine clean of sludge, etc.
    - removing unnecessary protrusions and lugs saves weight and looks elegant
    - I just like the looks of a smooth casting
    A typical head casting smoothed before doing machine work:
  27. mlagusis
    mlagusis
    Here is a 283 I cleaned up. Not the best, not the worst but good as I need for my beater.
    Blues4U, verno30, alfin32 and 3 others like this.
  28. lostone
    lostone
    from kansas
    Did it years ago to a 440. Smoothed everything, heads, block, water pump and housing etc. Lots of time and energy and of course lots of rolocs and sanding drums, downside? It didn't make it run any faster so its one of those "done it once, once was enough".
  29. NoelC
    NoelC
    You sure? By my calculations it became a slight bit more aerodynamic, that has to count for something.
  30. Roothawg
    Roothawg
    Well, there is that and lighter, so maybe less friction..... that's worth .0034*
    NoelC and 427 sleeper like this.
