Technical Smoothin’ an engine block
Discussion in 'The Hokey Ass Message Board' started by Heavenly Hearse, Jun 16, 2022.
  1. lostone
    lostone
    from kansas
    Lol!! ^^^
    Yeah I didn't notice any difference, of course it might have been one of those " feel it in the seat of yor pants" experiences I missed!
    Kind of like when you talk to someone who put a cam in their basically stock 350 and tell ya that they're sure it'd run low 11's now!! They can tell just by the way it runs.
    NoelC likes this.
  2. Hillbilly Werewolf
    Hillbilly Werewolf
    I am smoothing the spindles and steering arms on the DeSoto front end I am swapping onto my Plymouth. Not trying to go crazy but knocking off the forging lines to reduce stress risers and unsprung weight. I figure, with both sides done and my backing plates drilled, I will save about a pound total, and compared to my 10" brakes I am replacing, probably only gaining 5 pounds total. LOL
    raaf, alfin32, VANDENPLAS and 4 others like this.
  3. mgtstumpy
    mgtstumpy
    A PITA and time consuming however you won't see things when it's all bolted together Trans-1.jpg T700-2.jpg
  4. NoelC
    NoelC
    Well MGTSTUMPY, let me shake your hand and say it was worth it. Cause in my books it surely was seeing the end results.
    VANDENPLAS likes this.
  5. ronzmtrwrx
    ronzmtrwrx
    I did that to a 409 once for someone else. Yes once. It’s a pile of work. E3DF6C65-A3BD-46A3-BA30-CCF3D3FC7591.jpeg 9199186E-EB20-49CD-9557-AB4416636B53.jpeg 1F1C6AB8-4B41-409D-8CD2-67329D637792.jpeg F76B2019-E98E-4763-995B-254C7E54C6CC.jpeg
  6. lumpy 63
    lumpy 63
    I get it, I understand it... But I spend way too much time on the inside of the engine to worry about the outside. I do grind off extra casting flash and other imperfections, But honestly I cant justify the amount of time and mess it causes. I suppose if I was building a Riddler car it would be the thing to do. Sorry in advance Root:p
  7. seb fontana
    seb fontana
    from ct
    I was told by a Street Rodder [chopped 3w] that there is no way a smoothed [or chromed] engine will not overheat with out all the surface roughness to dissapate heat from the air blown on/over it by the fan.. He actually got pretty steamed..
    mrspeedyt likes this.
  8. Roothawg
    Roothawg
    Casting flash is not engineered into the cooling equation. It's a byproduct of casting molds. The new aluminum engines are way smoother castings than those of the 50's-70's.
    Someone should tell the aftermarket head manufacturers.......
    lumpy 63 and Deuces like this.
  9. Joe H
    Joe H
    That green 409 is a work of art, looks like a model car engine!
    Rickybop and Roothawg like this.
  10. 57 Fargo
    57 Fargo
    I can’t be bothered, the engine in the Fargo got rattle can flat black, no one notices it when you are busy driving them.
    mrspeedyt, nosford and Roothawg like this.
  11. Roothawg
    Roothawg
    Nothing wrong with that.
  12. indyjps
    indyjps
    I did a complete valley polish on SBC once. Not doing it again inside or outside.
    I do deburr / chamfer all rough and sharp edges on engines, no reason to leave the finger shredders there for later.
    SS327, verno30 and Roothawg like this.
  13. cfmvw
    cfmvw
    Never did the exterior of an engine beyond smoothing off some sharp edges and casting flash, but I did some smoothing on the inside of a Pontiac 455 to improve oil return to the pan.
    mrspeedyt and Roothawg like this.
  14. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    I did a motor recently and i ground all the flashing off and then retextured it with a air powered needle scaler. Looks great!
    961992B9-509E-44AA-A407-9F5F954F80EF.jpeg C3FE0B73-37CF-4677-913E-D6603553EE5E.jpeg 68C54C2A-1BC7-4983-B2BB-01DD369166FF.jpeg
  15. gimpyshotrods
    gimpyshotrods
    Yup, that's about all I will do these days.
    If I don't, I WILL be involuntarily donating blood at some point.
    SS327 and indyjps like this.
  16. I remove the sharp casting edges at the back of a Ford Flathead
  17. SS327
    SS327
    I’m kinda against painting the inside of an engine. Even with glyptal. So I polish the lifter area and all return areas. Smart, foolish waste of time, I don’t know but I feel better. On the outside I just try to remove the sharp edges. I already have more than my fair share of scars.
    Hillbilly Werewolf likes this.
