Technical Smoothing firewall on 41 pickup, ebrake help
Discussion in 'Traditional Hot Rods' started by 64Pony, Nov 28, 2020.
  1. 64Pony
    64Pony
    Spent the day filling holes on my firewall and now trying to figure out the ones needed for the emergency/hand brake.
    Does anyone have pictures on how the hand brake is bolted under the dash and how the cable is routed through the firewall?
    I got a hand brake for a 1940 but can’t figure out the mounting. Wondering if I’m missing additional brackets.
    [​IMG][​IMG]
  2. 40FORDPU
    40FORDPU
    Second pic shows the two mounting bolts to the right and slightly below the ID plate.
    The first pic is hard to make out but the other two mounting bolts are up next to the windshield which gets covered by the windshield trim.
    IMG_3616.JPG he cable routes through sharing the opening where the steering column goes.
  3. olscrounger
    olscrounger
    That looks like a 40 p*** car handle
  4. Dak Rat
    Dak Rat
    from NoDak
    Yup, you will need to find the truck handle--that one won't match the holes.
  5. 64Pony
    64Pony
    Thanks for the pictures and comments. Totally the wrong hand brake. Looks like I’ll be shopping for a another one. Does the cable go through the firewall as well?
  6. 64Pony
    64Pony
    A local member messaged me that had the correct part. Appreciate the help. Amazing how things bolt up when you have the right parts. lol
    Here’s the difference between the car and truck in case anyone needs a future reference. (Not too many photos of this online)
  7. Also On my '41 the cable goes through the bolt in panel around the steering column on the floor (upper left under carpet).
  8. hotrodA
    hotrodA
    Thanks for the brake ID with the pic
    Thought that the car was the same, too. Guess I’ll be looking for one now.
    Anybody got one laying around?
  9. 64Pony
    64Pony
    Another member “Bills 1940 collection” had one.
  10. 64Pony
    64Pony
    Thanks for the photo. The plate that goes around my pedals had two notches. I’m guessing these would be for the e brake and speedometer?
  11. Yes, mine has the parking brake cable through the top left notch and the speedo going through the notch on the right.
  12. hotrodA
    hotrodA
    @64Pony sent you a PM
