Hot Rods Snap On tool box drawers remove?
Discussion in 'The Hokey Ass Message Board' started by gus gustafson, Apr 12, 2017.
  1. gus gustafson
    gus gustafson
    Got a old Snap-On box at a swap meet ,need info on how to pull drawers out of box( non -ball bearing type guides) to clean ,some little hammering out & greasing up.. No little clips to be seen .. Snap on guy says a few bucks will get me a "special" tool.. I'm back in the boonies no snapy close by , must be sump'n simple to fab ?..thk/u. gus. MVC-010S.JPG
  2. 42merc
    42merc
    With your tool box you should have a pair of thin metal strips.
    About 1/2" wide X about 6" long with a 90 degree bend at one end about a 1/2" long.
    These strips insert behind the drawer slides with the drawer pulled out as shown.
    Insert the strips, then close the drawer, pull the drawer open holding the strips against the end of the slides. The drawer will be free.
    If you don't have the strips, maybe hacksaw blades will work.
    Edit: we have pics. Not great, but an idea.
    lothiandon1940 likes this.
  3. MrMike
    MrMike
    That's nice the snap-on guy can get you the special tool, mine just handed me a bunch and said hang on to these, the tool is a piece of thin sheet metal about .035 thick, about 3/8ths wide and 4 inches long, you slide it between the drawer and the guide as you slide the drawer out , its easier with two but I have used only one
    also the tool has a slight bend at one end about 20 degrees for an inch to hang onto, this is from memory
    so don't hold me to it, a valve lash feeler might work.
  4. metalman
    metalman
    yup. what 42merc said. I got some of those "special" tools, really any thin metal strip that will fit in the groove behind the slide will do. Hacksaw blade is a good idea if it's narrow enough.
  5. gus gustafson
    gus gustafson
    Special Thanks, on that "special tool".. Onward with some Gunk & mineral ,
    thanks for your time, gus.
  6. gus gustafson
    gus gustafson
    ground d teeth off couple Hack saw blades ,worked great ..thk/u all again, gus.
    never liked to go in those Sanpy trucks..Proto used to have better girly calendars..
  7. lothiandon1940
    lothiandon1940
    Funny how when you step into those Snap-on trucks your wallet becomes so light it practically floats right out of your pocket.:D:(
  8. Sheep Dip
    Sheep Dip
    from Central Ca
    No such thing as "a few bucks" with snap-on.....Glad you got it resolved.
  9. gnichols
    gnichols
    from Tampa, FL
    It appears the levers work in the same way as those slider bars that remove car stereos from their metal mounting cases. Good info - I've been wondering the same thing for years, as I got my tool box second hand and it didn't come with the release levers. Gary
