Features "Snoopy" Model A Hot Rod Survivor
Discussion in 'Traditional Hot Rods' started by Denns1989, Sep 8, 2014.
  1. Well here we go, I put the battery in, checked the oil, filled the fuel bowl thru the vent & then that's where the video starts :)
    Jet96, hendelec, Hotrod1959 and 16 others like this.
  2. After warm up, I opened the choke & gave it a couple shots...I still can't believe how these ol' flatheads idle, gotta love it.
  3. Yesterday was one of the first decent days we had in my area, which obviously required a trip to get Snoopy & drive him 45 minutes home for the summer, had to stop at the beach for a picture :)
  4. guthriesmith
    guthriesmith
    Very cool and great pic!
    Stogy, Nicholas Coe and Denns1989 like this.
  5. Nice shot! Show in Espanola this Saturday, I hear.
    Stogy and Denns1989 like this.
  6. Tim
    Tim
    from KCMO
    Looking sharp!
  7. cabong
    cabong
    Man, That's just downright cool !!
  8. Grease, Oil, Fluid Check, Adjust Brakes & then Wash / Clean Up was the order of the day today ! PXL_20220617_123829823.jpg
  9. One task I ignored when going thru Snoopy was the shocks, they had some form of resistance to them at the time & it was an easy enough task to deal with at a later date, recently when driving on the highway in very windy conditions it became evident that I might want to rule out defective shocks :) ... After some detective work it appears the fronts are off a 1950 Dodge Car - (Originally Front Application) & the rears are off a 1957 Ford Car - (Originally Front Application) because the fronts are a 5/8 bore top & bottom but the bottom mount on axle is a 1/2" bolt they shoved some homemade red plastic bushing to make up the difference, on the rear the lower shock connection was a cross pin that must have been cut off & driven out & then mounted using a 1/2" bolt to connect to rear axle. I'll confirm some measurements this evening & then get replacements ordered. PXL_20220626_221129950.jpg PXL_20220627_002157916.jpg
    Stogy, Jet96, Fitnessguy and 4 others like this.
  10. jebbesen
    jebbesen
    from Winona, MN
    Most hardware stores will sell steel sleeves that are 1.5" long with a .5 ID and an .625 OD. That's what I'm using on the top of my rear shocks. My car uses your 50 Dodge ones front and rear. Seems like the easiest way to deal with your rubber shim situation. 20220627_081757.jpg 20220627_081800.jpg
    Stogy, Jet96, chryslerfan55 and 2 others like this.
  11. jebbesen
    jebbesen
    from Winona, MN
  12. I was hoping there was an easy to get bushing for this, thanks for the heads up !
    Stogy likes this.
  13. jebbesen
    jebbesen
    from Winona, MN
  14. Tim
    Tim
    from KCMO
    What do those measure out of curiosity? Like sue to sue at ride height? Shopping for some new ones myself
    Stogy likes this.
  15. jebbesen
    jebbesen
    from Winona, MN
    1957 Ford ones.
    1949 plymouth ones
    Stogy, chryslerfan55 and Denns1989 like this.
  16. Tim
    Tim
    from KCMO
    Thanks!
    Nicholas Coe likes this.
  17. Drove myself batty last nite trying to find an exact replacement for the stem type shock, the 57 Ford dimensions were close but not exact, found this one which had the exact same dimensions as the one I had but had a dust cover & 5/8" lower mount, the dust cover will fit in there & I already ordered sleeves (&extras) for the front shocks so that's not an issue to step down to 1/2" for the mounting bolt. I'll post pics once they arrive & are installed :) Screenshot_20220628-072438.png Screenshot_20220628-072458.png
    Stogy, chryslerfan55 and jebbesen like this.
  18. Hitchhiker
    Hitchhiker
    Great to see Snoopy still getting loved and driven. You're a great care taker.
  19. Well, it looks like my shock choices are good, now just waiting on my Amazon shipment (sleeves) & then I can install... PXL_20220704_203141648.jpg PXL_20220704_202619765.jpg
    Stogy, simplestone, jebbesen and 6 others like this.
  20. Tim
    Tim
    from KCMO
    Thought of snoopy the other day when a friend shared this chevy bodied hot rod with me. Sure looks like they could have been running around the same neighborhoods doesn't it!
  21.
    Stogy and Tim like this.
  22. Last night when removing the rear rims to access the shock mounts I noticed a obvious difference in the paint colour on the rim where the baby moon caps cover, I have never known the original colour that was used, original owner said it was "probably a popular colour he had seen on a newer car at the time" considering the popularity of Inca Silver I had ordered a can of touch-up paint a couple years ago to use on the air cleaner, it was a bit to "grey/darker" than the paint... But I discovered last night it's a damn good match for the shade that been hidden under the baby moons for the past 60 years - which makes alot of sense. So I think it safe to say Inca Silver was the original colour. PXL_20220704_195344380.jpg PXL_20220704_230105040.jpg PXL_20220704_230053837~2.jpg
    Stogy, Jet96, simplestone and 5 others like this.
  23. ROADSTER1927
    ROADSTER1927
    looks right to me! Gary:)
  24. god damn you lucky guy. It cleaned up real nice, when it gets all situated you gotta see how fast that thing can go!
    An old man I worked for at his shop had a 1938 mercury convertible period rod he was going to sell to me but then he died of a heart attack and his son inherited it and destroyed it. So now i got this old jalopy but thats another story
  25. Well the sleeves arrived today (fit perfectly) so right after work I blitzed & got everything back together, as I just explained to my buddies:
    "She's mint, now it rides like an unloaded dump truck with new shocks, as opposed to an unloaded dump truck with no shocks..." PXL_20220705_210211063.jpg
    Stogy, Jet96, dana barlow and 7 others like this.
  26. how those bias plies holding up
    Stogy and Nicholas Coe like this.
  27. Thanks been driving it since 2015, it rolls along pretty decent - will cruise all day at 55 mph, had it up to 85 but it's starting to rev pretty good, oil pressure drops etc. & I don't want to detonate the flatty..
    Bias plys will have 8 seasons on them this year, no complaints, no weather checking, wearing even etc. All Good !
    Stogy, Jet96, dana barlow and 4 others like this.
  28. Tim
    Tim
    from KCMO
    Good deal :)
  29. Aye. I got Sears allstate 4 plies on and they hold up just fine. No point changing them then unless the dry rot gets too bad
  30. 8 years ago today, July 22, 2014, for the first time, I was able to see Snoopy & this is what I saw - I'll never forget that moment.
