Projects So, any ideas with this '32 Dodge?
Discussion in 'The Hokey Ass Message Board' started by 3Mike6, Sep 18, 2008.
  1. 3Mike6
    3Mike6
    Ideas of what you'd do to this?
    I've converted mine to '31 Plymouth axles in order to run 5 on 5.5 wheels.
    It's not my pic, I had to get it from the DBC site.
      41.9 KB
  2. Shifty Shifterton
    Shifty Shifterton
    Chop it 5 inches and lose the hood sides because they'll interfere with the early chrysler hemi. Disc brake the stock front axle and run wire wheels from a 50s mopar. Other than the requisite dual exhaust, transmission swap, etc for the hemi, don't change anything else at all.
  3. Arthur
    Arthur
    from NC
    You have a 32 Dodge pu? If it is complete and solid,why not put a later (1942 or newer) 230 cubic inch flat 6 Dodge engine in it? They can be bought cheap,have 130 HP stock,fit without having to hack a bunch of stuff up,and there is still speed equipment being made for them.
    Use a floor shift car or truck transmission. I think they stopped putting floor shifts in Dodges in 38,but they still used them in pickups right through 1948.
    If you have never heard a flat 6 with split manifolds and glasspacks running through the gears,you will be in for a real treat when you put it together.
  4. noboD
    noboD
    If you are over 5 feet tall and chop it 5 inches you probably won't be able to get in it. Drive it as is.
  5. 3Mike6
    3Mike6
    I have a fresh 218 (.080 over) and a fresh 318-not a poly-with a 727, I don't have a tranny for the 218 (rebuilt it for a forklift).
    I'm only 5'8...was also thinking a chiop since the cab is so "square", maybe 3-4 inches...5 inches would be cool, but might look out of proportion without channeling it?
    Thoughts about running with fenders and Running boards, or without?
    Not sure if a Hemi is in the budget, although it'd be super cool.
  6. Shifty Shifterton
    Shifty Shifterton
    With fenders and running boards please. It's a classy ride, don't join the fenderless truck masses.
  7. 3Mike6
    3Mike6
    I agree, especially since I have them, and they're very workable.
    What's your thoughts on a big chop and leaving it high? I'm thinking it might look "squished"?
