So, i broke a Grade 8 bolt........
Discussion in 'The Hokey Ass Message Board' started by ROADRAT EDDIE, Aug 4, 2006.
  1. Rocky
    Rocky
    Classified Editor
    I've read the hardware stainless bolts fall between a grade 5 and a grade 8 for strength.
  2. Oh ****... I'm crawlin under the desk until THIS blows over....
  3. striper
    striper
    ...and your set up does look mighty fine. I will apologise for my 'ratrod 2003' look ahead of time. I was going more for the 'ratrod 2006' look but I obviously missed it.
    Out of date before it hits the road ... :eek:
    Pete
  4. Hot rodders have been using spring hangers/perches fabricated from bolts and tubing for years.
    Both speedway and Total Performance use them in the suspension systems they sell:
    http://www.speedwaymotors.com/xq/aspx/paging.yes/dept_id.367/display_id.3308/qx/Product.htm
    http://www.tperformance.com/street_rod_store/front_suspension/spring_mounts/
    I don't think they would be in business if they had a reputation for killing off their customers.
    I could have fabricated the perches here. But I went with Bob because I trust his judgement and his welds.
  5. Darby
    Darby
    I don't know Bob or his reputation, so I speak only about what I see in the pictures, and what I see is scary engineering & fabrication. That welded-on bolt has been heat-treated to something other than Grade 8 for some or all of it's length. The welds look globby and I'd guess he only got partial penetration into the tube. Putting a cyclical bending load on brittle weld (***uming they weren't carefully annealed) scares me. I'm not saying I can weld any better, but I'd never drive on that, no matter how light my car was.
    As as for Speedway, they can sell whatever they want. Doesn't mean it's good or bad. They offer it in a chromed version, too, and I wouldn't dream of putting a chromed bolt in a suspension part. I don't have enough faith in a mail order hot rod catalog to understand hydrogen embrittlement and make sure their suppliers prevent it.
  6. I don't know much about your ride or how it is built but I'm going to suggest that the bolt wasd defective. A 1/2" grade 8 bolt should hold up just fine in the type fo situation that you describe.
    Where did it break? the most natural place for it to break is where the threads meet the shank unless your threads are at a shear point, the threaded part of the bolt is its weakest [place, if you had cut threads that makes them even worse.
    What you want is shank at the shear point and threads only outside of that area. i usually try and set my suspensions up so that the shank of the bolt p***es through whatever is being bolted and then use a flat washwer out side of that to take up the space between the threads and the mateing surface for the nut.
  7. HOLLYWQQD
    HOLLYWQQD
    from central NY
    any one here able to tell me if i'm gonna die on my set up i have a picture of a set of mock up bones with old batwings done exactly as my new **** was done . here. i had my fab guy take a set of total performance bolton spring perches and cut a large diameter whole in the outside of the bone and a smaller (bolt size) diameter whole in the inside and insert the perch through the bone . he then welded all around the outside and then went to the inside and instead of threading a nut on there he cut the bolt threads off about an 1/8th" from the inside surface and went all around that area with a weld . any opinions on this from the metal masters ???it seems perfectly fine to me and i'm gonna run em. but i'd like to know what ya'll think.
    i thought i had a picture in my computer but i don't . i'm gonna have to take one tomorrow and i'll post it
    thanx
    jp
  8. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    The bolt at the top was the one that came out of the other side....The broken one was identical.
    [​IMG]...The break is exactly where the perch lies flat against the bone.....If you read one of my other posts it says that when i went to ***emble it with the new bolt, i had to loosen the jamb nuts on the bone and the drag link to pull the axle back about 1/4" to 3/8" so i could line up the bolt going through the bone and into the perch, meaning that there was some foward pre-load on that bolt.....Now, was that enough to cause this?.....I don't know, but i can't imagine it helping the situation
    What your saying about the bolts makes a lotta sense, but it almost sounds like you need custom bolts, since i need a 1'2" x 1 3/4" bolt with at least a 1/ 1/4" shank......My brother works in the aviation field and if this ****er was fine thread, any size bolt wouldn't be a problem
  9. Killer
    Killer
    does this broken bolt go from the outside of the bone and thread into a nut thats welded onto the shackle part??
  10. AN bolts are available in every 1/8" increment of shank, with just enough threads for a washer and nut. They are avail. in co**** thread for special applications (read: more money:( ). I would recommend counter-boring about 1/2" of threads out of the perch, reaming it to size and then get a bolt with enough shank to go all the way in there. That way the shank is carrying a lot of the side load instead of the thread. We do this on all the critical single shear attachments on the race car, and have yet to have a failure other than crash damage...
    Just my .02...
  11. Blownolds
    Blownolds
    from So Cal
    That bolt is being used IMPROPERLY! Bad design. Get Carrol Smith's books "Nuts Bolts Fasteners and Plumbing" and "Engineer to Win" and read them to see how bolts should be used.
  12. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Where?....I've looked online and don't see any descriptions of shank lengths
  13. 29 sedanman
    29 sedanman
    from Indy
    I have a Lawson Products catalogue here at work and have the part numbers for the supertanium bolts that Roy was talking about if any one needs numbers for them.
  14. Killer
    Killer
  15. PS, They're actually avail. in 1/16ths, that's what the number after the hyphen is. It is the shank length (no thds), NOT overall length like hardware store bolts.
  16. Kevin Lee
    Kevin Lee
    Super Moderator
    Yup, I'm waiting too - I've read the whole thread and still can't fully figure out how the bolt was used from the pictures.
    My guess: The bolt goes through the split wishbone and into the tubing part of the perch - which is threaded something like a tie rod or drag link? And you basically had three threads holding each side together?
    If so, we shouldn't even be having a discussion about strength of grade 5 versus grade 8. This entire thread should be dedicated to proper use of fasteners as Blownolds has already touched on.
    I don't want to bag on how you built your car but scrolling down to look at it again - holy hell that is insane. You can see by the three dirty threads on the remaining bolt and stripes around the shank near the head that there wasn't much holding anything. Not even "square" with the size of the bolt.
    Can you show an exploded shot with all of the parts laid out?
  17. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Ding, ding, ding........We have a winner!......
    I didn't put this thing together....yep, just three threads per side holding it together....Have longer bolts in now temporarily but am working on getting the bolts with the right shanks........
  18. Killer
    Killer
    bolts with the right shanks ain't gonna do you ****. you're just rockin that perch on those threads..
    That bolt is being used wrong. Time to lookup at Blownolds post, find that book and have a read... doesn't matter if you built it or not... you need to fix it right!
    buy perch bolts and slide em through your bones. I wouldn't use the welded style shown above.
  19. Blair
    Blair
    from xx
    Good advice.
    There is NO WAY I would trust a 1/2" co**** bolt in single shear supporting the load of your front end.
    As for the co**** thread being stronger than fine thread it depends. If its in shear then co**** isn't stronger because the root diameter is smaller on a co**** thread bolt so it will shear before a fine thread. If it is threaded into a weaker material where the material will fail before the bolt in tension (strip, pull out, whatever you want to call it) Then a co**** bolt is the better choice. This was all mentioned earlier.
    As for stainless, if I remember correctly (don't quote me exactly, I don't have a design book handy) 316 stainless has about a 35 ksi tensile strength, whereas mild steel is 36 ksi. Grade 5 and 8 are much higher. There are grades of stainless that don't necessarily have the corrosion resistance but have much higher strengths. For the most part all a hardware store has is 300 series stainless. This also was said earlier.
    Bolt strength, size, thread type, and material construction needed varies a great deal depending on the loading.
  20. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Is this what you mean? Crude drawing, but the shear point is now on the shank which is the proper way......The bung that the bolt goes into is tapered, i would imagine for the taper on the bolt to fit into.......[​IMG]
  21. Mart
    Mart
    Longer bolts will not help, as stated above. The design is unsafe. DO NOT DRIVE the car.
    Quickest and easiest fix would be to buy a pair of early ford perch bolts, drill right through the bones, p*** the new perch right through the bones and weld both sides (really well, no pigeon ****) then cut off the excess bolt that's sticking out.
    Be sensible, be safe.
    Mart.
    PS if the person that built that front end was responsible for the rest of the car I'd have a good look around the rest of it.
    M.
  22. Some one has probably already pointed this out but that's a corse thread bolt. You don't have anyway near enough thread in the socket and to get it the way I explained earlier you just get a longer bolt and cut some of the threaded part off. The longer bolt will have more smooth shank.
    DOH I just saw your drawing, yes that's the shear point where the two pieces of metal that can slip past each other meet. A lot of the felas are useing a apring perch that has its own bolt that p***es trhough the bone with a nut on the other side. I think a stock A perch bolt comes pretty close to matching up.
  23. SnoDawg
    SnoDawg
    Another thing that scares me is that there is no positive way of locking the bolt into place. Are you using some lock***e? Me I would drill the head for a safety wire so it wont work loose. But that is the Aircraft mech in me talking.
    Dawg
  24. Kevin Lee
    Kevin Lee
    Super Moderator
    Do what you want. I just don't like the idea of that component being bolted on like that. Weather Speedway, Bob Hindman, or anyone else built it. And the idea of those style perches being able to rotate on axis and self align while in use is silly. They don't need to.
    I would just stop worrying about what kind of bolt to use. Ditch the fasteners alltogether and break out the welder.
    I wouldn't be able to drive that car again until I'd taken Mart's advice.
    Good luck man. Seems like all things considered you've been pretty damn lucky so far.
  25. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Okay, so can i use one of these?.....It's too long but cut it flush and weld both sides?......The hole it's going through id double walled.....Still need a sleeve?......Also, need a 29x1 3/4 main leaf......Anyone sell single leafs?
  26. Kevin Lee
    Kevin Lee
    Super Moderator
    Yeah, look at those pictures posted earlier for how they're used. Get those, not chrome, and poke them through the holes. I've never done this but I'd say chamfer the outside holes (facing the tires) heavily. And not chamfer at all on the inside. Use that taper on the perch against the wishbone to fill with a good hot weld. Then fill up the chamferred part on the outside the same way.
    Then cut the remaining bolt from the outside off and dress the weld.
    I think Mart and others have already suggested this.
    I've seen some people use sleeves and some not. I personally don't see the need for them. Anyone care to add to this? Like I said, I've never done it but it seems like the right way.
  27. MIKE47
    MIKE47
    from new jersey
    If you are going to weld the perch bolt right to the bone then a sleeve won't be needed. Sleeves or bushings are to support the bone with a hole in it. The perch bolt will do the same thing. If you want to be able to remove the bolt for some reason then a nice tight bushing welded on both sides would be in order, then a good quality locking nut. I say get a new spring, perch bolts and shackles from Posies (fast delivery to our area and excel. quality), set up your perch bolts nice and straight and weld 'um right to the bones. Tig them if you can or have someone do it for you to be sure there is a good,clean penetrating weld.
  28. CLSSY56
    CLSSY56
    I've twisted a 3/8" grade 8 bolt off by hand, might even of been a 1/2" using a 1/2" drive before and no cheater bar. I have a problem of "it can go a little tighter..."
  29. BluesHound
    BluesHound
    I admittedly didn't read to the end of the thread, so if my following two points have been covered please ignore...
    I believe hydrogen embrittlement issues can arise from yellow zinc plated hardware as well. Regarding design, be sure that all of the shear planes in your application are in the shank of the bolt. I made the mistake once of placing a shear plane at the transition between the shank and the threads, after breaking a couple of bolts in testing I put in a longer bolt and fixed the issue.
