so im almost done with my swap
Discussion in 'The Hokey Ass Message Board' started by Clutch810, Sep 15, 2011.
  1. Clutch810
    Clutch810
    from clovis ca
    so im done with my SBC swap but i need help with the wireing can anyone give me a diagram for the 54 chevy 210 for the SBC 350?
  2. Master of None
    Master of None
    Have you converted the 54 to 12 volt before the swap?
  3. Clutch810
    Clutch810
    from clovis ca
    no we didnt know were to start so i said lets do it after we got the motor set and got it running. all the help is appreciated
  4. Clutch810
    Clutch810
    from clovis ca
  5. chaddilac
    chaddilac
    You running a aftermarket wiring harness? If so you'll need a factory wiring diagram for the headlight switch and ignition switch... and what gauges are you running? You'll need to install a voltage drop down for those if they are originals and are 6V, plus all your lights will need to be 12V bulbs.
    What ignition are you running, HEI or points? all this stuff will need to be known before you can get a wiring diagram and I don't think you'll find one very easily.
  6. Clutch810
    Clutch810
    from clovis ca
    ive got a hei ignition and im using the stock gages i was going to wire it up my self.
