So its snowing here, I built this. Now what do I do?
Discussion in 'The Hokey Ass Message Board' started by Internet, Jan 16, 2012.
  1. Mr48chev
    That's a nice looking first effort. You kept the drop real smooth.
  2. tfeverfred
    tfeverfred
    I've never seen a rig for dropping them.:eek: This thread will be a learning tool.:D
  3. temper_mental
    temper_mental
    from Texas
    I have one almost just like this one I bought it form a guy in a model A club. I always snicker when I use it. Looks great to me!
  4. Anderson
    Anderson
    Whoa, nice work man!!
  5. Woob
    Woob
    from Falcon, CO
    I'm flipping back and forth between the two pics. Does the slide get adjusted down before the bend or does the axle get jacked up to it?
  6. Internet
    Internet
    didnt want to start a new thread, i got around to measuring the axle.
    chalk outline on the bench has the drops perfectly even.
    but the reason i posted again, i mounted a set of spindles on the axle, and without adjusting the axle. there is 1.5 degrees of NEGATIVE camber on the left and 2 degrees negative on the right. from my days of playing with auto cross cars for friends that is a pretty optimum camber setting.
    what is the stock model a camber angle?
  7. Hnstray
    Hnstray
    from Quincy, IL
    Wish I knew for sure, but I'm betting it's to the positive side...probably a degree or so.......will be anxious to see when someone posts the number.
    In any case, I admire what you have done here. Pretty impressive.
    Ray
  8. Internet
    Internet
    just found it. bias ply tires. 1-2 degrees postive and radial tires 0 degrees.
    hmmm. i wonder if i will just f*ck it up trying to do it. maybe i will just have it aligned after the car is completed if i use this axle.
    anybody ever actually measured the camber on a street driven rod?
  9. need louvers ?
    need louvers ?
    Usually pretty close to 0 on most aftermarket axles.
