I already have a mid 40's axle that I'd like to use on my A frame. It looks cool and will save some dough. I've done a couple of searches and have come up with some great info, but I still have a lingering question. I'm planning on using some Heim joints that I already have a the the end of the wishbones. Will there be too much lateral movement in the front end? Does anyone recommend running a panhard bar up front? Any other safety related concerns I should be aware about? Thanks in advance
If you run a "dead-perch" on one end of the cross spring, and panhard bar will not be required. Otherwise, YES as alreadt stated....
A dead perch is a spring perch that has the shackle built in. The shackle part doesnt move like on a normal "live" perch. It works to control side movement like a panhard bar. The other side of the spring uses a normal shackle and perch. You can make one or buy a version from the Deuce Factory. As for the Heims, they are harsh compared to urethane rod ends or tie rod ends. They can also wear excessively on the street. If you run them, at the very least run a large washer on the outside to "capture" the end in the event of failure.
Here are some pictures of a dead perch as Tman described. http://www.rodtech.com.au/DEAD%20PERCH.htm Chris
I hear that trout works as well as Perch. Thanks, the dead perch looks like a much cleaner installation. Are there any drawbacks? Also, with regards to urethane bushed rod ends, I noticed that some have offset angles versus a tie rod end that is moveable. Which is the preferred end? Last question: Do I want my wishbones running parallel to the ground or parallel to the frame rails?
I would stay away from the Heim ends. Use tie rod ends. They are strong and most importantly, they look right. Wishbone should be parallel with the ground for the proper look. My 2 cents for what it's worth.
All those are loaded questions that the answer will vary depending on your frame setup. Rod ends, I used straight ones on my touring and a couple other setups, I ANGLED the mounting bung on the frame. That is, I happened to use thickwall DOM that the mounting bolt ran all the way through. The DOM is welded into the frame at an angle so the rod end doesnt bind. I like the urethane rode ends Pete and Jakes. Most on the HAMB will guide you to traditional tie rod ends, either will work, the tie rod as you noted will allow for some mis-alingment. As for your bones, you need to worry about caster first. Then see where the bone hits in relation to the frame rail. Mine hit right in the center of the rail. On some cars, you will find that the bones end up several inches BELOW the rail. In odd cases, the bone will hit above. Look at some of the cl***ic cars from history that run bones, most look good with them parrallel to the ground or running dowhill slightly to the rear. If your bones are not hitting where you want them, you can take a pie-cut like slice out behind the front forged yoke and re-weld. Think of the Bleed sweep only done on bones. If you cut from the top down, this will allow the rear of the bone to mount higher than when it was uncut.
