Hot Rods So lets talk about late model overdrive transmissions in a 35-40 Ford
Discussion in 'The Hokey Ass Message Board' started by Roothawg, May 8, 2015.
  1. 1pickup
    1pickup
    easy to identify the 200-4R, it's the one puking trans fluid out the front seal. or. should i say, puking the front seal out of the trans.
  2. Hnstray
    Hnstray
    from Quincy, IL
    Tsk, tsk, tsk......that is SO cynical! :D
    Ray
    270dodge likes this.
  3. russellmn
    russellmn
    I'm plugging a T5 from an 88 Mustang into my 35 behind a y block. around here, S10 T5s are everywhere, so I'll get a tailshaft housing off one of them if I need to move the shifter forward...
  4. okiedokie
    okiedokie
    from Ok
    Hey Roothawg, be sure and keep us updated as to mods to wishbones and center section.
  5. fatkoop
    fatkoop
    Put a 2004R in my '36 coupe. Previously had a 350TH in its place. Had to cut the x-member pretty hard to clear the trans. pan. The drive shaft is a direct swap. Not finished yet, but I'm anxious to have the OD. Any ideas on hooking up the TV cable when using 2-4's? Not very much room from the firewall to the rear carb.
  6. figure8
    figure8
    Got me thinking about replacing a TH 350 with the 200 4 r.How about the converter. Are they lockup so they need a switch wired in like a 700 r4?
  7. Roothawg
    Roothawg
    They have both Figure8. OKieDokie follow the LeGrange Produce build thread, I will cover it there.
  8. Hnstray
    Hnstray
    from Quincy, IL
    Yes, they are equipped with lock up converters.
    Ray
  9. okiedokie
    okiedokie
    from Ok
    I have been and will continue, nice job.
  10. jt40
    jt40
    from Beloit Wi
    Hi there I was wondering if you ever did the 2004r install in your 40. Just wondering what you had for front suspension. and how everything turned out. I want to do this to my 40 coupe while retaining the wishbones. Right now it has a early ch***is engineering split wishbone kit and a th350. Thanks
