so, sleeved block or o-ringed cylinders?
Discussion in 'The Hokey Ass Message Board' started by 62rebel, Nov 16, 2012.
  1. 62rebel
    62rebel
    the 289 i bought has been bored .030 and it has what appear to be copper or bronze rings around each cylinder, about 1/4 inch away from the bore and standing proud of the deck somewhat. i don't have pics of it, as it's still at work. hoping a Ford guru will shed some light on what i have here.... and that it's not simply junk. the bores are really clean, after getting the pistons free and rotating the crank several times, spraying liberally with wd-40... the cam lobes aren't scored, and the lifters aren't galled. i'm su****ious that it might have been sleeved (odd, for a common engine like a SBF) and that it won't take another bore in case it needs it.
    if it has been cut for o-ringed head gaskets, i'm kind of curious as to why they went to that much effort on a 289. ****, i really need to get some pics of it up here.
  2. Pictures would be nice. Do you know if you have stock pistons? The 0-rings my have been added because the motor had high compression pistons or was running a blower. We don't think of the 289 as much these days. But there was a time.......
  3. If it's just a thin ring, it's likely o-ringed. Who knows, maybe it had twin turbos or something in the distant past...
  4. mart3406
    mart3406
    from Canada
    Yep.. O rings....usually used in
    conjunction with with dead-soft
    copper head gaskets to seal the
    cylinders and prevent blown head
    gaskets on very high compression
    or high-boost supercharged or
    turbocharged engines.
    Mart3406
  5. JohnEvans
    JohnEvans
    from Phoenix AZ
    And any of the light weight casting engines like the 289 family you really don't want to bore p***ed .040 as heating issues usually follow . Every 350 CSB I've been around that was bored .060 had over heating issues. So in my opinion you are done at .030.
  6. GTOMUSTANG
    GTOMUSTANG
    from ct
    Due to four bolts around each cylinder, O ringing was recommended for boost, but it could show up in other builds. Its gap should be near a bolt, so that the clamping force pinches it shut.
  7. theHIGHLANDER
    theHIGHLANDER
    I vividly recall a certain 65-6 Mustang Cpe at Det Dragway. It was a 289 4spd, and I swear that guy musta been swingin it close to or over 8K RPM. Damn that car could sing. Fast too, like low 11s-high 10s. I also heard of a 289 in a slingshot dragster here in Motown. I tried to get more info in an attempt to buy it but got shined on. Supposedly it was a blown 289, the motor was still in the garage, the car was hung from the rafters. Some folks loved those lil peanuts...
  8. seb fontana
    seb fontana
    from ct
    Piston dome would tell us a lot..What are the heads like? Even a number off the cam would give a clue as to the general build of the engine..
  9. Taylorengines
    Taylorengines
    from Brea, Ca.
    Small fords will sing if you have the foot for it ! oh and wallet..
  10. snaptwo
    snaptwo
    I've still got one of those in my Dads 'ol Bronco , think it runs great but it only has about 60k on it. O-ringing a block would have to been an extreme machining job, not a round deal like a hemi . I do recall that Doug Nash used a blown 289 in an early bronco funny (truck) ? "Bronco Buster", gl*** body with an aluminum ch***is , even the rollcage !!
  11. Cantstop
    Cantstop
    Like the other guys said, the only guys that really do the o-ring thing anymore is the boost guys.
  12. 62rebel
    62rebel
    they are thin copper or bronze rings, and the pistons are forged flattop at .030 over. i'm getting a better "warm and fuzzy" feeling now. i'd be glad to pop some pics up as soon as i can haul it home from the store's backroom where i had to leave it.
    i'm a true believer when it comes to the "haul-***" that a 289 can do; my Dad had a stock '67 Mustang with one in it, that would definitely SCOOT.
