Projects So this is how it starts "T" RPU
Discussion in 'Traditional Hot Rods' started by chlsnk, Jun 5, 2025.
  1. chlsnk
    chlsnk
    from Kansas
    Love to hear that I had a feeling. Although it's kind of a the fact they where just banging around with all my other parts loose in a box.
    Outback and Tim like this.
  2. chlsnk
    chlsnk
    from Kansas
    Found a few hours today to get out in the shop, I was able to get the three lasalle cases painted inside with red glyptol and brushed on a ford tractor gray to the outsides. Modified a spare side shift case with a ford trans mount to get an idea where my trans crossmember will sit seeing as the lasalle trans is a few inches longer. Was hoping to mount the engine far enough forward to avoid cutting up the A rectangular crossmember but no dice. Hoping to get my wish bone mounts dialed in and welded on tommorow now that my engine is sitting square and level in the frame rails.
  3. Tim
    Tim
    from KCMO
    Cool :)
    chlsnk likes this.
  4. chlsnk
    chlsnk
    from Kansas
    Recent focus has been on wrapping up the radius rods. Mounting plates inboard on the frame rails hopefully for a better turning radius made a pie cut at the yoke to bring the rods closer to the frame ending with 8° of caster.
    I think down the line when I find a nice set of longer later model radius rods I'll revisit this project. Not thrilled with the look of the short "A bones" but they will do for now. 20250919_192754.jpg 20250919_193706.jpg 20250919_200718.jpg 20250919_200631.jpg
  5. chlsnk
    chlsnk
    from Kansas
    Had some time to spend on the car today, picked up a pair of NobelSpeeds new laser cut mounts and worked them over to better fit what I had in mind they are based on the deminsions from the VernTardel book. I found these mounts far superior to the speedway universal type mount I was using previously, right now they are bolted to the stock shock mount holes 2" from the back of the crossmember. I will be adding a third bolt from the topside although i think its unnecessary. Body is still just sitting inplace going to work on steering next. Gathered up all my model A U-bolts for a quick media blast and thread chasing. I thought a few where too far gone but they all cleaned up nicely. 20250928_190945.jpg 20250928_190959.jpg 20250928_151038.jpg 20250928_174439.jpg 20250928_183842.jpg 20250928_190600.jpg 20250928_190619.jpg
    Outback, hook00pad, Deutscher and 2 others like this.
  6. chlsnk
    chlsnk
    from Kansas
    Had my friend Zac drop by on his newly finished scooter to address some loose nuts and bolts and he was able to help me get the body set back on the chassis. Choppers go hand in hand with hotrods.
    Outback, dwollam, hook00pad and 5 others like this.
  7. Grumpy ole A
    Grumpy ole A
  8. Tim
    Tim
    from KCMO
    Looks great!
  9. chlsnk
    chlsnk
    from Kansas
    Not much done this week startered whittling down the F1 cross member and am working on body placement basing everything off centering the rear wheel arch over the axle. I was hoping to avoid entirely cutting out the factory ford center cross member but the added length of the lasalle transmission is forcing my hand. Tore down a gritty looking F1 steering box and was pleased to find it in incredible shape internally. 20251004_174715.jpg 20251004_174738.jpg
    Deutscher, Outback, Mikko_ and 3 others like this.
  10. Tim
    Tim
    from KCMO
    Really taking shape!
  11. chlsnk
    chlsnk
    from Kansas
    Really second guessing the f1 cross member, with added length from the lasalle transmission my pedals will be quite a ways back. I scooted the body back as far as I could and it helped some. Considering cutting the center out of the cross member and staggering either side of the cross member forward to get my pedals in a better spot. I cut nearly all the factory center cross member out but it looks like it will all need to come out.
    Deutscher likes this.
  12. Tim
    Tim
    from KCMO
    Yeah sometimes it’s just a day for a trip to metal by the foot and start from scratch.
    Deutscher and Outback like this.
  13. chlsnk
    chlsnk
    from Kansas
    I haven't given up on it yet but we are approaching that point.
  14. chlsnk
    chlsnk
    from Kansas
    Tired of sitting idle I made the decision the old crossmember was coming out, welded a few spars across the top and bottom of the frame some tack welds on the front cross member for bracing. Lacking a duplicate set of regulators for my torch and the plasma cutter on loan the center punch a pile of dull drill bits my favorite hammer and a sharp chisle I set to work knocking out all the offending rivets. Glad to see I can still *mostly* swing a hammer only smoking my chisle hand once. The cross member is out. Slipping the F1 unit in made it all worth it, lots of pruning to go but I think this will work nicely. 20251012_143613.jpg
  15. Tim
    Tim
    from KCMO
    lol that’s a nice wall hanger award ya got there
  16. chlsnk
    chlsnk
    from Kansas
    Work has been crazy coming to a close this year which has been good for the pocket book but hasn't left much time for hotrod activities.
    F1 Crossmembers are more work than they are worth, I've fought this one and finally got fed up with making it beautiful and functional as I go and settled with functional. We set to work with the torch and welder making the F1 member fit. After extensive measurements a placement was settled on that will allow some factory frame holes to be used for mounting and hanging puck type engine mounts off the back the ford 3spd spacing was able to be maintained. Decided against welding in the crossmember incase I pull the lasalle and go back to a 39' 3spd in this chassis. Going to buy some steel and work on some legs to turn the crossmember into a K-member. 20251109_164416.jpg 20251109_164429.jpg
    osage orange, treb11, brading and 3 others like this.
  17. Tim
    Tim
    from KCMO
    Ain’t mad at that.
    chlsnk likes this.
  18. chlsnk
    chlsnk
    from Kansas
    *side note* This is the F1 crossmember I ended up using because it was already hacked and I knew I was going with a non standard transmission so it would be cut up anyways. When I mocked it up I found it was perfectly clearenced to the shape of a lasalle. Makes me wonder if the truck I salvaged it from was using a lasalle aswell.
    Tim likes this.
  19. brett4christ
    brett4christ
    Contact @Pinewood here and ask him about his F1-in-A-frame K braces. I have a pair I'll be putting in B4Cdan.
    Outback, Pinewood and chlsnk like this.
  20. Outback
    Outback
    from NE Vic
    I had wondered about an F1 cross member. Haven't heard much positive about fitting them
  21. brett4christ
    brett4christ
    Mine fits just right for my application...with a "few" changes...
    Still have some finish welding to do, then final fitment. Also the addition of K-legs from @Pinewood and removal of the original A crossmember.
    26 T Ford RPU likes this.
