so what did you get done this weekend?
Discussion in 'The Hokey Ass Message Board' started by uncle johnny, Jan 17, 2010.
  1. uncle johnny
    uncle johnny
    weather is a little better outside.
    so what did you do in the shop this wekend?
    i started on a truck bed.
  2. Hotrodtoms
    Hotrodtoms
    made a start on my tunnel and firewall,
  3. hrm2k
    hrm2k
    I fixed some bird strike damage on the grill insert on my car. Had to add a new piece so the damaged expanded metal had something to hold onto :eek:
  4. terd ferguson
    terd ferguson
    I rebuilt my carb and then snapped my vacuum advance hard line. One step forward, two steps back.
  5. koolkemp
    koolkemp
    Got most of the work done on my 47 Fords 59 C[​IMG]hevy dash installation.
  6. Anderhart Speed
    Anderhart Speed
    Nothing. Had to take the airco tig to the welder repair shop-and I have a lot of welding to do. Did clean the garage though
  7. jetcycles
    jetcycles
    got the 50 deluxe running like a top. . .and discovered a leaking master cylinder.
  8. low-n-slo54
    low-n-slo54
    fixed the driverside quarter panel.
  9. Baizie1999
    Baizie1999
    from The Ky
    Nothing. Both kiddo's sick. Not much fun here.
  10. Went from this:
    To this:
  11. flamed34
    flamed34
    Just about finished all the body work on the p***enger's side body on my '34...and now fitting and chopping the p***enger side door.
  12. 50scotbolt
    50scotbolt
    Dragged the truck out,gave the engine a run,sussed out a misfire,topped up the anti- freeze(a bit late...ooops!) and checked it over after recent cold spell.(unheated garage)
    Block and freeze plugs OK....... Phew!
  13. tudorkeith
    tudorkeith
    got my 1/4 panel down to metal, welded the trim holes generally got a lot done.
  14. jdubbya
    jdubbya
    Finally started to take my engine out of my truck, to make room for something new and improved. I also supervised at HotRodGary's house while he chopped the top on his bug.
  15. vernmotor
    vernmotor
    from ohio
    work on a hummer (sheet metal work) and work on a vega (race car) more sheet metal and work on my bead roller ..got a steering wheel on it now and turns free..
  16. ranchwagun
    ranchwagun
    Kick *** dash! I have been looking for just the right one for my '46 this inspires me!!!
  17. captainjunk#2
    captainjunk#2
    i went to the springfield ma autoparts swap and sell , nothing much there for what we build , but it was a good walk about hey uncle johnny thats a sharp looking truck you are working on ,
  18. George G
    George G
    Drywall on my ceiling. It's a true friend who willingly helps you on a job like that.
  19. HotrodTrash
    HotrodTrash
    from Hanford,ca
    installed my new starter, made templates for my windows, charged battery, Found leaky wheel cylinder.
  20. thunderbirdesq
    thunderbirdesq
    New rear subrails and wheelwell patches...
  21. Master of None
    Master of None
    Not much unfortunately, and fortunately i spent the weekend fighting a house fire in town. fortunately the owner wasn't hurt and none of our guys got hurt. There's always next week...
  22. mutt423240
    mutt423240
    went to allentown, pa for an indoor car flea market. had a goood time
  23. Master of None
    Master of None
    Ment unfortunately sorry.
  24. 56gasser
    56gasser
    from lower al.
    patched another hole!!
  25. Started the cowl steering in the A, got the cage in to support the box and started to make the brackets to hang the box.
  26. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
    I work on my frame and my engine.
  27. Domino
    Domino
    Nothing, absolutely nothing. The Falcon is still in the field and the Galaxie is still in a million pieces. The rain kept me from doing anything. At this rate I will have half of one of these cars together by 2020.
  28. Stevie Nash
    Stevie Nash
    Daughters basketball tournament ALL day Sat, and football on Sun. Dammit!!!!!
  29. 296 V8
    296 V8
    from Nor~Cal
    Dropped this DEUCE heavy for HAMBer Jalopy-Joe
  30. Von Rigg Fink
    Von Rigg Fink
    from Garage
    put the body back on for final radiator placement mock, and Deuce tank mock.
    and a few other measurements that i needed. battery try etc..
    ****ty camera phone pictures sorry
