Hot Rods So, what do you think is the coolest hot rod engine ever?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Mar 30, 2016.
  1. 52HardTop
    52HardTop
  2. falcongeorge
    falcongeorge
    from BC
    For bader2, from my hoard...
    But before you rejoice too loudly, yup, thats a big stack of 327 chevy rods and TRW L2165F's beside it...
  3. 52HardTop
    52HardTop
  4. falcongeorge
    falcongeorge
    from BC
    Does this help ease the pain? not mine, just a pic.
    rod1 likes this.
  5. LostBoy
    LostBoy
    Anything Straight eight.
    Nailhead Jason and kidcampbell71 like this.
  6. wicarnut
    wicarnut
    ALOT of Kool looking engines posted here, I'm a SBC guy, But if $$$ was no problem, I think a DOHC Ford/Foyt Indy car engine in a High Boy Roadster would do it for me. I think w/electronic fuel injection and backing off, cams and compression, it could be made to work. Would this be practical, probely not, ridiculously expensive, yes, more than likely, a very high dollar boat anchor, but the thread question is, what do I think would be Kool and good looking. All the standards are Kool, dressed Flatheads, Nailheads, BBC, SBC, Cads, Olds, any engine looks good if detailed properly.
  7. falcongeorge
    falcongeorge
    from BC
    Highlander, do I have a story for you. Early seventies I was probably 13 yrs old I am walking down the street, I see a scruffy looking, primer spotted pilothouse Dodge PU with Chrome reverse wheels on it and ladder bars with the hood up. So I cross the street to see whats up, and under the hood is a sq. pt. BBC with a 950 3bbl on it!
  8. chevy57dude
    chevy57dude
    I'm a BBC guy 'cause torque is king. But the Hemi is just a visual whopper.
    ****** - I know the Cosworth is OT, but damn I want to put one in a T speedster!
  9. chevy57dude
    chevy57dude
    SBC haters can hate, here's an actual 'vette engine. Then again, they all are, right?
    AndersF, Jet96, 56don and 1 other person like this.
  10. Shamus
    Shamus
    from NC
  11. don daddyo
    don daddyo
    Nailheads are my cup a tea...but mostly all of them...flatheads,chev 265.327.and more kool engines ,to much to name it...
  12. DDDenny
    One time at band camp...........
    Bandit Billy and Jet96 like this.
  13. Roothawg
    Roothawg
  14. atch
    atch
    Root,
    With your talent and propensity for makin' little sbc's run I have no doubt that you could make a little pickemup truck do wheelies just like the Fly. BUT; I'm still hopin' that you go the nailhead route...
  15. Roothawg
    Roothawg
    One of the things that holds me back is the lack of good pistons for the Nailhead.
  16. Bader2
    Bader2
    Stack of Chevy rods? How many did you blow up? I've done half a dozen, and earned the right to call em a pos.
  17. falcongeorge
    falcongeorge
    from BC
    Its funny a ford guy would pick rods as the subject of a anti-chevy rant, if I wanted to make fords look good, I would avoid the topic of rods. Chevy doesn't do any broach cut rods. Ford does.
    Never broken a chevy rod. EVER. I shift my daily driver 355 at 7000, the short block is virtually stock. I have built sbc's with steel rods that were shifted at 8000. If you are breaking chevy rods all the time, you are doing something wrong.
    I own sbc's, sbf's, an FE, an Olds 324, a Desoto Hemi, and BBM's, so its pretty hard to make the case that I am a "chevy guy", or that I have any bias.
    dan31 likes this.
  18. Bader2
    Bader2
    Same could be said about the sbc. Tired,worn,and wasn't really cool the first time it was mentioned.and it's not a hot rod engine,it's a street rod engine.
  19. Bader2
    Bader2
    I've never broke Chevy rods either,spun bearings is another topic altogether.
  20. falcongeorge
    falcongeorge
    from BC
    This is a photo of a broach-cut 302 ford rod. Ford also used this machining method on all 289s except 271hp, 351 Windsors, and 429's and 460s, with the exception of truck and 429cj or SCJ rods. They do it because its cheap. As pretty much anyone can see, it creates a m***ive stress riser right across the thinnest part of the rod.
    Anybody with any experience racing small-block ford will try to side-step the question of rod strength when they are on an anti-chevy rant, the rods are the most pronounced inherent weakness in small-block and 385 series fords.
    Bias, right? My first car was a 302 Pinto, I currently have a 428FE, and I have a factory 4-speed '65 Futura HT that I am putting a 331/toploader in, and I have a mid-sixties style 289 T-bucket project that the XF-8 I posted is ear-marked for. As well as all this stuff, over the years, I have built 289's, 302's 351 clevelands (and have one under my deck right now) and a 460 for other guys.
    Chevys, mopars, and frankly everything else I have ever built, used spot-faced rods. Even Ford basically admits that the cheapo broached cut rods are junk, they didnt use them in the 271hp 289s, or Boss 302's or 429CJ's or 429 SCJ's. Those are the facts.
    This is why when EXPERIENCED Ford engine builders go on an anti-Chevy rant, they try not to talk about rods...;):rolleyes:
  21. Bader2
    Bader2
    And still,your the only one that even mentioned rods?
  22. O.Hove
    O.Hove
    from S.D.
    For eye candy it has to be Early Hemi's , Chevy W , and a 12 or 16 cly flathead.
  23. falcongeorge
    falcongeorge
    from BC
    I also run the chevy oiling system STOCK, right down to the pump, I dont even use a high-volume pump. I use a deep pan, but I do it to keep the oil off the crank, and I run 5 in an 8 quart pan with one in the filter. Irony is, I do extensive oiling system mods to Clevelands, FE's, and 429/460's.
    Bader, if you like Fords, thats great, so do I, but if you are going to constantly bash chevys on here, at least try to come up with some reasons that have at least some basis in fact.
  24. falcongeorge
    falcongeorge
    from BC
    Your words. Am I missing something here?? I know, I know, no point in arguing with some people, black is white, up is down...
  25. Bader2
    Bader2
    Yay you! Don't hurt your arm patting yourself on the back! Run whatever you want,just don't tell me what my opinion should be George! It'd be a pretty boring world if we were all in love with the same girl.
  26. Bader2
    Bader2
    Obviously.
  27. tb33anda3rd
    tb33anda3rd
    not a hot rod engine?
    steinauge and kidcampbell71 like this.
  28. Bader2
    Bader2
  29. Lots of way cool engines posted. For me it's a solid lifter, aluminum headed, three duck 427. 68_L71.jpg
    falcongeorge likes this.
  30. falcongeorge
    falcongeorge
    from BC
    I do...:rolleyes::D
