So what have your learned recently
Discussion in 'The Hokey Ass Message Board' started by tstellhorn, Nov 13, 2008.
  1. tstellhorn
    tstellhorn
    So what have you learned recently - either the hard way or the easy way. Usually I end up learning the hard way, but the most recent thing I learned I actually learned it the easy way - at least it didn't end up ruining a perfectly good part (which makes it an easy lesson in my book). Here's what I learned: I was in the process of remounting the carb on my truck - had it all bolted in place and was starting to attach the fuel line. The line that runs from the flathead pump to the carb is a copper line and it doesn't really line up very well. As it turns out, I started pulling and pushing on the line attempting to get the fitting to thread into the pot metal carb top of the Holley 94 carb. What I learned, before actually stripping the threads of the carb top, is that when working with copper fuel lines and pot metal it's better to attach the fuel line to the carb first, then attach the carb to the intake instead of the other way around. I came to this realization just in time to save the carb!
    Anyone else learn something recently - either the hard way or the easy way - that they'd like to pass on - and hopefully save someone else a ton of grief?
    Todd
  2. well i learned today that a comerical super heavy duty pressure/steam washer will cut right thru a great qulity pair of boots and geting them high top boots off in a hury don't work.....and will cause 2nd - 3rd degree burns...:eek:...................and it will hurt:mad:.........................i also learned that 2 injections of of dilada pain killer will make you just about forget ya did it...:p.................and make your ass type very slow;)...............don't think i'll be getting much done on the topolino for a bit either......:(
  3. Leon
    Leon
    I learned it sucks having dimensia
  4. Bash'n'Weld
    Bash'n'Weld
    Heat warps sheetmetal!!......shit.
  5. striper
    striper
    Firestone tyres are expensive
    Learned that the hard way
  6. kustombuilder
    kustombuilder
    from Novi, MI
    i learned that Elvis died 3 days after my 3rd birthday! i also learned that the official cause of death was NOT a drug overdose, as is commonly held to be true, but rather heart failure due to a defect... his father ordered an independent autopsy but that he ordered the results to be sealed until something like 2026!
    ...damn. was hoping i was the first smartass to jump onboard this ship but then i looked back adn saw Topolino Kid's post... hey, would love to come out and see that Topo some time. i love those things!
  7. Jalopy Jim
    Jalopy Jim
    I learnt on tuesday it is a long drive from Rapid City SD to Elk River Mn in the freezing rain.
    The week before I was taught at metal meet : to weld a patch panel on use my 110 wirefeed set on high, set the tip at about a 45 degree angle to where you want to tack and hit the trigger for a instant, repeat every three inches, gring off the highspots using a 6inch grinder disc, hand file to perfection, and keep repeating until done. There was no warping and there was no visable seam.
  8. Westside Lefty
    Westside Lefty
    from Venice
    I learned that if I want something done right, I must let someone else do it.
  9. droplord49
    droplord49
    from Bryan, Tx
    Amen brother.
  10. farmboat
    farmboat
    from Lucas, KY
    I learned that if you have a late model DT466 and you are losing large quantities of oil with no visible signs of oil loss, the fuel injectors are leaking oil back into the fuel tank.
  11. GreggAz
    GreggAz
    I learned that new spst relays have a diode in them to protect electronic devices, and if wired backwards that diode pops instantly!
    it took four 15 dollar relays to find the problem, and one 4 dollar relay with no diode to fix it.
  12. JOECOOL
    JOECOOL
    I learned after 42 years of marriage my wife can read my mind, and that folks is real scary.
  13. invizibletouch
    invizibletouch
    from Mobile, AL
    When you chop the roof off a car, you better support that fucker or you'll spend 4 extra weeks getting everything lined up again! :)
  14. Stick004
    Stick004
    from Missouri
    Always... ALWAYS. Buy the good stuff first. Because you'll just end up replacing that cheap shit later.
    And... that I should listen to my friends.
    Because they have been telling me that for years!
  15. I learned yesterday that when you go to the emergency department on a Saturday for a work related injury that happened the day before you had better make sure the doctor fills out a Workmans Compensation form!!!! I have had an injured hand for 2 years now and have to go in for surgery. When I asked about time off on comp she found it had never been written up for comp. Sucks to be me.....
  16. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I've been learning a lot about brain tumors.
  17. I have learned that, as much as I hate to admit it.....I STILL have a lot to learn!!!:rolleyes:
  18. Degreaser
    Degreaser
    Do tell... hows that work?
  19. chaos10meter
    chaos10meter
    from PA.
    You can put dam near 2 gallons of antifreeze in a small block if you forget to close the block drain cocks.
  20. There is no gravity, the world sucks!-MIKE:mad:
  21. Brad54
    Brad54
    from Atl Ga
    I learned that the front bearing cover bolts on an A-833 4spd OD trans are NOT blind holes, and in fact all four of them go right into the 6 quarts of gear lube inside the trans. At the same time I also learned that one of the bolt holes for the side cover is the same way, though the others are blind holes.
    It took me the better part of 6 months, a permanently stained driveway, an undercarriage that looks like the Exxon Valdeze, a wasted clutch disc and a lot of gear lube thru the trans to figure this out.
    -Brad
  22. gnichols
    gnichols
    from Tampa, FL
    Before you use an air wrench on your serpentine tensioner pulley bolt, make sure it is either a left or right hand thread. Gary
  23. 40StudeDude
    40StudeDude
    I learned, after 65 years on this planet, that you never stop learning something every day...
    I learned there are still people out there that still don't understand this concept...
    R-
  24. hotrodladycrusr
    hotrodladycrusr
    That I am not perfect....or right all the time
    :D
  25. 3Mike6
    3Mike6
    Well, I learned my SBF MM's are not symetrical side to side, but one sits about an inch further back than the other...ofcourse I learned this AFTER I welded in my MM plates to my chassis.
  26. r8odecay
    r8odecay
    that the 30 dollar Lisle tappet puller don't work in 51 caddy 331 lifters.
  27. Kripfink
    Kripfink
    I have learned that Autoloc tri-bar headlights do not in real-life bear much more than a passing resemblance to their photograph:mad:
    Paul
  28. Hot Rodz R Us
    Hot Rodz R Us
    That the people that offer to help you do something, are always the first to quit....
  29. hombres ruin
    hombres ruin
    i learnt that Tijuana tuck n roll is a great thing.Champions in TJ is a great shop that can do anything upholstery related.I went down there with my friends 54 caddy coupe deville,and hell what a job they did.They did my floor mats,and package tray.We had no problems with anything it was all professional.Anyone want to go there for a TJ tuck n roll adventure we will love to be your guide.
  30. scootermcrad
    scootermcrad
    I've learned that the bigger this place gets the more retarded threads get posted and push good threads to the bottom.
    Just sayin'
