Hot Rods So what is this car that followed me home
Discussion in 'The Hokey Ass Message Board' started by old chevy, Feb 12, 2023.
  1. old chevy
    old chevy
    I am not a Ford guy so I am curious what this is. Lady who had it called it a clown car used in parades. It had been sitting for 25 years in same spot. So now I have a new fine auto to mess with. Just curious of year it may be. Actually frame is excellent and body is not too bad so it will be slightly modified for a driver and keep me occupied for a while. So now I need for someone to tell me what it is. Guessing at least a 31 or 32. Doors are bigger and interior has enough room to fit me in it.
    Thanks for help.
    Jalopy Joker, VANDENPLAS and Petejoe like this.
  2. old chevy
    old chevy
    Sorry about photo being turned but i don't know how to rotate them
    Ed
  3. Looks like an 30-31 Model A truck with the roof wacked off
    56don, lurker mick, Squablow and 6 others like this.
  4. It was a 1931 Model A Ford based on the one piece splash apron (which I ***ume is original to the car).
    There is a serial number on the frame but you need to lift the body to see it. Definitely not a '32 because of the shape of the frame.
    Charlie Stephens
    Squablow, Deuces and clem like this.
  5. Rickybop
    Rickybop
    It's your hot rod roadster pickup now.
    joel, VANDENPLAS and Cooon like this.
  6. 51504bat
    51504bat
    Steering column looks Model A based on the throttle and spark levers but the wheel is definitely a later Banjo style.
  7. gene-koning
    gene-koning
    Is there anything on the tag on the firewall?
  8. 31Apickup
    31Apickup
    1930 to may 1931 Model A cab with roof cut off.
  9. old chevy
    old chevy
    Thanks. That is about what we were guessing it to be. It does look like it got a home made crew cut but should be interesting to do. Will get to it in a month or two and pull body to see numbers on frame. There is no numbers showing on firewall on that small tag.
  10. Mr48chev
    The data plate on the firewall originally probably looked like this. OOOPS it's below the Vicky firewall
    The Model A Victoria body I had had a plate below that plate with a number printed on it that was the body number from the body builder as far as I can figure.
    VANDENPLAS and Deuces like this.
  11. Deuces
    Deuces
  12. hotrodjack33
    hotrodjack33
    Model A's serial/registration numbers were the engine block number. Some Model A frames had that engine/ serial number stamped on the frame...some didn't...it depended on which plant ***embled it. @Charlie Stephens called it right with the 1 piece splash apron...mid to late '31
    41 GMC K-18 likes this.
  13. 31Apickup
    31Apickup
    It hard to say year just from the apron as many of these were a hodgepodge’s of parts. It’s odd to have a p***enger side spare, as a pickup would have had left side. Stuff has been swapped or pieces together.
  14. 0NE BAD 51 MERC
    0NE BAD 51 MERC
    I take it no paperwork came with it. Is Texas an easy place to get a bonded or reconstructed / kit car ***le in? Here in Wisconsin, it is not too bad as long as you follow the rules. Sadly, a lot of people don't and look for short cuts and end up with all kinds of headaches. If you have to go the bonded route .do it now. Its present condition establishes the value of the bond. In the unlikelihood of a previous owner popping up he is only en***led to the value of the car when you got it. They are not en***led to the car or the value when it is done. You will most likely need it inspected before they issue the plates once it is road worthy. But that's not too bad. Here in Wisconsin, it would need some type of fenders over the tires. something that resembles bumpers and lights, turn signals and windshield wipers, seatbelts, basic safety stuff. A roadster pickup would be a fun daily summer cruiser. Have fun. Larry
    2Blue2 and Beanscoot like this.
  15. Its the front half of an A touring. IE Tub.
    That make good Lakes Roadsters or good roadster pickups. Or if you have the back half that make delicious fendered hot rods. Short front gl*** and hammered cloth roof and etc.
    Never mind all that. I put my gl***es on and now I see that I am totally mistaken. :oops:
  16. rockable
    rockable
    I think it was Jed Clampett's truck. :D
  17. ramblin dan
    ramblin dan
    That's really cool. I called about one similar a few years back but didn't get to her in time. $_59.jpg
  18. Squablow
    Squablow
    Not a bad starting point, what's left looks pretty decent.
  19. dwollam
    dwollam
    Those are '31 car running boards.
    Dave
  20. old chevy
    old chevy
    Interesting finding out all the various parts on this clean little auto. I appreciate all the info as I have never been around Fords before. The front fenders both sides have the slots for spare tires also.
  21. old chevy
    old chevy
    The crazy little auto has spares on both front fenders which I didn't understand. True collection of pieces bolted together.
  22. rusty valley
    rusty valley
    Clown cars for parades were usually model T's with the rear axle moved forward so they could do wheelies . Wish I had one !
