So, what's a bubble top?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Jan 6, 2009.
  1. Groucho
    Groucho
    I know 61 GM 2 door hardtop cars are called bubble tops, but why NOT a 59 or 60 GM 2 door hardtop?
  2. Boones
    Boones
    from Kent, Wa
    I always thought just the 62 with the 61 roof was called a Bubble top.
  3. hotrod-Linkin
    hotrod-Linkin
    59-60-61 and a few 62 gm 2 door hardtops with the big back window
    chev,buick,pontiac,olds,caddy
  4. Tony
    Tony
    Same here. The only one i've actually called a bubble top was the 62. The other's we've always just called hard top's. hmm.
  5. JLasvegas
    JLasvegas
    from Skin city
    I had a 61 impala bubble top, it has a pronounced hump compared to the 61 sedan
  6. KidAgain
    KidAgain
  7. I always thought it was 61/62 belairs with the curve in the top of the back gl***
  8. This is a bubble top
      32.4 KB
  9. KidAgain
    KidAgain
    If you get one that's a factory 409 4speed its a zillion dollars, that's what it is.
  10. 33Tudor
    33Tudor
    No. That's a Double-bubble top!
  11. Pontiac also offered that type of top.
  12. KidAgain
    KidAgain
    Nah, that's a watermellon patch.
  13. Tony
    Tony
    I'm pretty sure Groucho know's what one physically is. From what i gathered, he's heard of 61's being called bubble tops, but not 59 or 60's and just wondering why.
    I'll explain why we've always just called the 62's bubble tops.
    In 59-61, the only car without a post and two door was the one with the "bubble top", in 62 is was a belair hard top, but also not the only hard top offered as i'm sure you already know..
    So, the standard hard top in 62 with the notch in the roof always seemed to be called the hard top, the other belair model with the carry over roof like the 61 was the bubble top.
    This i believe is, for the most part, the same for the other GM full size line's of those years as well.
    This is just what i've always understood, and made sense to me.
    In essence, they are all bubble tops in comparison to the other models offered in those years i guess..
    I know you didn't ask this, but i figured i'd at least explain why i said what i did up a ways.
  14. hotrod-Linkin
    hotrod-Linkin
    that's what i said....
  15. TheMonkey
    TheMonkey
    from MN
    hmm. i reckon it's the rounded gl*** and slight pillars that makes the difference.
    Pontiac was '61 only.
    '61 Bonneville:
  16. Groucho
    Groucho
    If you guys re-read my original post, I said GM cars. That includes Pontiac doesn't it?
  17. TheMonkey
    TheMonkey
    from MN
    but.... 1960 Pontiac has similar gl*** and pillars, so I'm not sure why that one is not known as a bubble. look forward to hearing the answer, someone will have it.
    1960 Bonneville:
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    you can sit in the back seat and look straight up and see the sky, At least you can in my 61 impala. I think thats why its called a bubbletop, pontiac buick and oldsmobiles were that way
  19. Groucho
    Groucho
    And you can't in the 60 pictured above?
    I've had people say all 61 GM 2 door hardtops, with the roof they used on the 62 Belairs were bubbletops, but NOT 59-60 GM 2 door hardtops with a very similar roof and rear window. Why?
  20. Royalshifter
    Royalshifter
    Moderator
    I had a 61 Caddy that was a bubble top.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    I guess that I have considered 59 and 60's bubbletops too
  22. BadLuck
    BadLuck
    The 62 hardtop had a little "crease" in the roof kinda simulating a convertible top, the bubble tops did not have the crease and flowed right into the rear window....if you want, i can post a perfect example of the two....i have a pics of both....
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    If you look at the pic above of the 61 it does look like the rear gl*** goes farther forward on the roof than the earlier ones
  24. hotrod-Linkin
    hotrod-Linkin
    i've called all those roof lines bubbletops since they came out and not changing this late in my life...you guys call them what you want..i've got to go take some maalox.
  25. Groucho
    Groucho
    We're NOT talkin 62's (with the exception of the Belair). But, that's not really the issue here. Re-read original post:(
  26. hotrod-Linkin
    hotrod-Linkin
    not all 62's had that crease.some were bubble tops.we have one here at wesco chevrolet in okc.
  27. Groucho
    Groucho
    So, is it your belief the 59-60's are not considered bubbletops by some for that?
  28. IF you look at the gl*** it's self on a real bubbletop it has a curve in the top of it unlike a 59/60
  29. Django
    Django
    from Chicago
    Agreed. Prior to that they were just "hard tops".
  30. Tony
    Tony
    I've never seen that view before to compare, but they sure are different.
    I can see why some people would consider them different now and not call them all bubble tops.
    Interesting...
    I still just call em hard tops :)
