soda blasting an intake manifold ?
Discussion in 'The Hokey Ass Message Board' started by dirtbag13, Apr 1, 2010.
  1. dirtbag13
    dirtbag13
    found an old offenhauser three deuce setup over the weekend and was dissasembeling it for clean up ! took it to the local machine shop to have it hot tanked , intake looks to have been polished at one time , mostly grime and overspray on it i was gonna have em gl*** bead it but wondered if anyone has soda blasted one ? its not really a cast looking manifold so i'm trying to stay away from the etched look gl*** beads give ! pretty smooth surface and wondered if soda blasting would do the trick ? i'm not going for a polished look when done just smooth aluminum
  2. fullhouse296
    fullhouse296
    from Australia
    Yup , soda blast is the ticket .DONT .have it hot tanked ! The caustic in the brew will attack looneymum .
  3. 49ratfink
    49ratfink
  4. mac762
    mac762
    Hot tank aluminum and all will be left are the bolt holes. :) My buddies vo-tec teacher was always saying that.
  5. dirtbag13
    dirtbag13
    guess i should have used the word hot tanked loosely ! not sure what they use but i have had them do aluminum before no problem !
  6. Shaggy
    Shaggy
    from Sultan, WA
    For polished, just hit it with some mothers mag and alum polish
  7. T. Scott
    T. Scott
    SODA BLAST is the way !!! clean it good and send it in
  8. Rocketile
    Rocketile
    from USA
    As long as you are just looking to shine er up. Soda blast will not touch any heavy crusties.....
  9. 325w
    325w
    Be sure to give it a good cleaning after the blasting. We gl*** beaded an intake years ago and after the motor was run for a little while the bearing went south. Now I cover all openings before any kind of blasting. Then lots of water. Two scents
  10. blt2go
    blt2go
    soda blasting is actually a darn good degreaser. i did an inline 6 that had valve cover issues for probably 20 years, never washed, just pulled it and blasted it whole. made tear down clean and easy. a word of caution; if you have to really "dig" at grime with a big blaster you will break through the polish and leave it a little hazy but as said before a little mothers and you'll be back in business. the other plus is soda breaks down with water so no abrasive issues come back to haunt you.
