Soft Shocks
Discussion in 'The Hokey Ass Message Board' started by old1928fordguy, Jun 25, 2010.
  1. old1928fordguy
    old1928fordguy
    from colorado
    I have a 29 roadster high boy. As you would imagine it has no weight in the rear end. I have a stock spring but it only has 5 leaves. I put on some tube shocks from Napa but they are gas shocks and way too stiff. Is there any where to buy old ,just soft hydraulic shocks. Any suggestions for a soft tube shock. Thanks Phil
  2. How do you know a shock is too stiff? Am I to assume this is a running and driving car?
    How are they installed, what angles and how much travel at ride height. Some information would be nice.
  3. sxdxmike
    sxdxmike
    the more you angle them the less effect they should have right? so you could 'soften' things up that way.
  4. revkev6
    revkev6
    from ma
    what shocks did you get?? I get rear shocks for a 1948 ford from napa. I figure they weigh close enough to the same once you put a bigger motor in it.
  5. dump the gas shocks and get some regular cheapo 50/50 shocks
  6. pasadenahotrod
    pasadenahotrod
    from Texas
  7. brandon
    brandon
    i tried some gas shocks on the front of my a .....waaay to stiff , just shook when i hit anything.....went to a PRO shock from speedway . they offer them in different lengths , might be worth a look:D
  8. Unkl Ian
    Unkl Ian
    VW Beetle fronts.
