Soften Hardened Steel
Discussion in 'The Hokey Ass Message Board' started by iammarvin, May 16, 2013.
  1. JonF
    JonF
    Use Elmer's white glue on the drill bit. This works for drilling springs
  2. crazy_tonguezz
    crazy_tonguezz
    from glendale
    if you can put it under a drill press. you can get a nail and install it into the chuck,and put preasure on the piece at high rmps untill the metal gets blue and then you can drill through it , old memory here
  3. crazy_tonguezz
    crazy_tonguezz
    from glendale
  4. BRENT
    BRENT
    ! C A R B I D E ! that is your answer! Or EDM, good luck!
    Brent
  5. belair
    belair
  6. canadianal
    canadianal
    from canada
    Discer blades are really tough. We use the thick ones for gong targets they will crack and break before you will put a hole through them other than military solids or really big stuff . I dont have an answer re drilling them. we use a torch to put holes in them to bolt a chain on.
  7. pasadenahotrod
    pasadenahotrod
    from Texas
    Friend of mine had some tall car stands made of discs with a pipe between the two. Very stable, never thought of using them for hubcaps.
  8. Engine man
    Engine man
    from Wisconsin
    If it won't soften with the heat, it might have a lot of manganese in it. If you need it countersunk you could try punching a hole. Take a sharp center punch and clamp a Visegrip to it. See if you can make a mark so you can find the correct spot. Have a large hammer ready and an ***istant. You need to heat the steel to nearly it's melting point, white hot. When it starts to melt quickly hand the torch to the ***istant and use the punch and hammer to punch a hole through the white hot metal. This is how they put holes in horse shoes and steel rims for wooden wheels.
  9. toxic waste
    toxic waste
    from Iowa
  10. iammarvin
    iammarvin
    from Tulare, Ca
    Blew a hole thru this **** with my torch, tried to drill it on my press..........NO way!
    No more f ing with this! Thanks all..........
  11. Engine man knows what he is talking about! If I had to try drilling it I would get carbide masonry drills. For a 7/16 drill I would run about 400rpm no coolant and lots of pressure. You are trying to get the steel hot enough right at the drills cutting edge so the drill can dig into it. If at first it doesn't cut use more speed! wear protection as the chips should be orange to yellow hot. If this method doesn't work, give up and have the holes EDMed or water jetted by a pro.
  12. 29AVEE8
    29AVEE8
    Beat me to it.
    Contemplating this causes me to "furrow" my brow....
  13. Truckedup
    Truckedup
    Then install a rear sway bar :D
  14. 1952henry
    1952henry
    All in all this thread cultivated some good thought.
  15. Kevin Lee
    Kevin Lee
    Super Moderator
    Traditional hot rods, guys.
