This truck comes with a brand new box from Mac products. This includes the stainless strip and the oak wood floor, which has been stained and urethaned Fibergl*** front and rear fenders and running boards. Has a Hood and grill and a steering column It has a brand new, in the box, 14 circuit wiring harness It is an original frame, boxed front and rear Rear suspension is a 2016 Ford Mustang 8.8 posi disc brakes Front suspension is Heidts Tubular upper and lower A arms, Power rack, disc brakes The transmission is a brand new 700 R 4 dynoed The engine is a crate 350. It also has been dynoed Aluminum intake Chrome Holly carburetor Mini torque starter Alternator and power steering pump and brackets Gas tank is installed in the frame Has cowl vent and upper dash cover Have windshield frame and windshield crank out mechanism Rear brake calipers are included Engine, transmission and drive shaft are installed in the frame The ch***is is painted silver I do have another 37 cab, that is better than this one. It can be swapped for this cab. I also have steel front fenders, rear fenders, and running boards, if you want to choose to make an upgrade. I also have a very nice 37 hood and 37 grill, which can be purchased separately, or offset for the one in the picture and price adjusted. There is a ***le If you do not want the rolling ch***is, and you want your own, I can make a price adjustment. Call Brian with any questions. Nine 2 zero, three nine 3, 2 seven nine three.
