1937 LaSalle transmission and NOS Offenhauser adapter. This is the nicest untouched original transmission you are likely to find. It shifts perfectly and is very tight. It came out of a hearse and still has the original paint on it. It has a later LaSalle U-joint on it. It comes with an NOS Offenhauser adapter to a flathead. $2000 firm 1938 Buick top loader transmission with a 1951 Oldsmobile open drive tail-shaft. This comes with an NOS Offenhauser transmission adapter to a flathead. Unfortunately, the transmission case is cracked. It needs a donor 38 Buick trans case. Cool and different transmission. $550 1939 (ish) LaSalle side shift transmission with an aftermarket floor shifter. The shifter is spring loaded making the transition between 1st and 2nd smooth and fast. Nice tight transmission. SOLD 1950 Oldsmobile open drive tail-shaft. This is the one year only tail-shaft that is often used in the conversion of LaSalle transmissions to work in cars that cannot accommodate the longer LaSalle tail-shafts. $500 Located 15 miles south of Cleveland Ohio. I will crate and ship at the buyers expense. View attachment 5741520
