1964 C10 SWB Patina!! Clear title. Super straight body with minor rust. Couple pinky holes in rockers, some minor rust coming thru on the floor along the inside door sill (carpet and sill plates would cover it) and a hole at the bottom rear of the driver's side fender. Nothing structural that needs to be addressed before driving. It looks like the truck was restored in the past. Interior was painted silver, not pewter. No ashtray or dash heater control plate or any heater parts(shown in pic). Dash has not been cut. The bed is in awesome condition, except the wood of course, but all metal strips are there. Have a nice seat and a couple manual steering columns and steering wheels as well. NO rear suspension has been built. Step notch is welded in. NO wheels or tires. NO drivetrain. All new parts except rear end. Front end partially mocked up to set ride height. Porterbuilt parts have been powder coated black. Chassis: • KP Componenets step notch • DJM 3" HD drop spindles • Porterbuilt Extreme front dropmember for bags (includes SBC mounts and trans cross member) • Porterbuilt 1" narrowed tubular control arms • Porterbuilt front sway bar kit • Unisteer power rack & pinion • Front shocks • (4) Air Lift 2600 Dominator air bags • Porterbuilt 63-72 adjustable rear trailing arm crossmember with carrier bearing mount • Powdercoated Porterbuilt parts • 83 C10 10 bolt rear end with spring perches removed Other parts: • Accuair E-Level kit with rocker switch • Accuair VU4 valve unit • Accuair power supply wiring kit for dual compressors • Ekstensive 8.5 gallon air tank • Brake Performance front & rear rotors black coated drilled and slotted • Speedway weld on rear D52 caliper brackets • (1 pair) Willwood BP10 brakes pads • Wilwood red D52 rear caliper (bought one to mock up rear caliper brackets, planned to run these front and rear) • Front rotor hardware (i.e. bearings, seals & grease caps) • (7) Spohn Del-Sphere joints (for triangulated four link) $7000 If you plan to come haggle Gas Monket style, don't waste our time. I am not selling because I need money. If it doesn't sell it will sit till it gets done. Possible trade for 1972 or older car or truck. Two door cars only unless it is a wagon.
