Sold!! Up for sale is a very nice S10 T5 transmission with a 3.97 ratio first gear. This transmission number is 1352-192, out of an 1989 S10, and is perfect for an early Ford Hot Rod. This is the non- World Class version. This transmission bench shifts smoothly and feels good in all gears. Endplay feels good. As most of you know, the S10 trans is perfect for a hot rod since it has the shifter close to the bellhousing and works well with a bench seat. This S10 tranny has following ratios that I verified by putting it in gear and turning it on the bench. 1st: 3.97 2nd: 2.34 3rd: 1.48 4th: 1.00 5th: .79 The gear ratios on this transmission make it great for a hot rod, and the T5s are very light and compact so they fit in most applications. It bolts right up to a small block chevy with the standard chevy bellhousing. May need a little trim of the input shaft depending on the application. Perfect for a Flathead Ford. These T5s are becoming harder to find. I will ship on buyer's dime, which will run about $170. Feel free to contact me with any questions you may have
