T5 overdrive, 5-speed, manual transmission package. This is a World Class trans from a Chevy S-10 Complete package ready for installation or conversion: T5 trans with preferred shifter location for smaller cars Custom Shifter Aluminum bell housing Adjustable fork ball Clutch fork Throw out bearing 168 tooth flywheel McLeod pressure plate McLeod 11 inch composite disc Wilwood master cylinder Speedway slave cylinder Energy Suspension trans mount -3 SS braided line from master to slave Custom bracket to mount slave to bell housing All flywheel, Pressure plate, trans to bell-housing and trans mount bolts included This set-up has 800 easy break-in miles - you can still see the flywheel grind marks/pattern - EVERYTHING WORKS PERFECTLY! I am selling because I converted to an automatic - yes, I am getting old. The ONLY think you will need is a shift knob $1800 - will not separate - THANKS! Jake - 720-201-1525
