Time to sell my stuff. I have had this 60 Cad tri power motor sitting under my work bench for about 28 years. Never used it and time to sell. It is a 390 with the jetaway trans. still attached. It is froze up. It has all the carbs and most linkage but missing a vacuum pod. But who cares if you are going to hot rod it. The air cleaner is there but someone cut off one of the snorkel's and moved it to the side and welded it on. Why? Who knows? It looks like it could be removed and welded back on to the original piece. Or just buy a new snorkel from the guy making them on ebay. Also has some small hammer marks in the rear of it. Probably to clear something. Only thing i see missing is the fan blade, which might show up around here somewhere. Still under my bench and will be removing it soon. Make a good hot rod motor or original if you have an old Cad. $1500.00 firm. Firm. Firm. If calling and you don't get an answer, just leave a message and i will get back to you right away. I do not text, i do not text, i do not text. 8one8-two0three-four03nine.
