34 fibergl*** roadster body, Dan Fink Windshield, and frame. as you see it in the pictures. The frame has decent rails that are buildable with front and rear crossmembers. Center crossmember has been cut. Unsure brand of body, It is an older body with removable trans tunnel and will need some body work to be a show car or build the frame and leave the body alone for a good driver. Includes dash, guages, steering columns, and gas tank. (Tank not pictured) No ***le but does have numbers on frame. located in Taylorville, Illinois 62568. $6500.00obo
