**SOLD**
Discussion in 'Cars For Sale' started by Jim P, Oct 28, 2014.
  1. Jim P
    Jim P
    from Tyler, TX
    City: Tyler
    State: TEXAS!
    Price: $25000 obo
    Due to some personal issues I am selling my 1932 ford roadster. I have 327 that can go with car but will need rebuilding. I have a NV3500 5 speed from a late model s-10 for transmission. No wheels and tires to go with the car. You would need your rollers. The car is ***led in my name with 18****x vin. Not much left to purchase or do except plumb brakes and exhaust, then blow a part for paint. Here is a list of the other parts I could think of that I have for the car most of which are new:
    Radiator (used)
    Motor Mounts
    Transmission Mounts
    1932 Ford Rolling Ch***is
    Trunk Latch
    Headlight Bar
    Roadster Body
    Windshield with gl***, posts, & Stanchions
    Pedal Pads x 2
    1932 grill insert
    Grill trim ring
    Original Firewall
    Banjo Steering Wheel
    Early Ford Drum
    Foam for panels & 3 cow hide leather
    Gauge Panel
    License Plate Frame
    Steering Column Drop 4" - '32 Style
    Telescoping Throttle Cable
    4 - SS Bolts (4"x1/2") Rear Spring
    Hood Prop
    Center Hood Strip
    Hood Latch
    Hood Lacing
    Hood Lacing
    Center Hood Bump
    Grill Shell Bull Nose
    " Emblem
    " Radiator Cap
    Fuel Sender
    Trunk Handle
    Tail Light Brackets LH
    Tail Light Brackets RH
    Tail Lights LH
    Tail Lights RH
    Interior Escutcheons (comes as a set)
    Exterior Door Handles x 2 (each $26)
    Door Handle Pads x 2 (each $1.30)
    Female Dovetail (sold as a pair)
    Mail Dovetail x2 (each $5.95)
    Cowl Lacing - Hood to Grill Shell
    Cowl Lacing - Hood to Firewall
    Cowl to Firewall seal
    Cowl Vent Seal
    Trunk handle Pad
    " Striker
    Car Tag
    Door panel clips
    Cowl Vent Lever
    Headlight bar emblem
    Front Seat Frame Roadster
    20 Louver Hood
    S**** Gas Pedal
    Grill Shell
    Shock Mounts
    Master Cylinder
    Residual Valves (red-front)
    Residual Valves (red-rear)
    P*** through Fittings
    34 Commercial Headlights H-5 Bulb
    Spreader Bar - Front SS
    Spreader Bar - Rear SS
    Sanderson Shorty Headers
    Zips Water Pump Riser
    Gas Tank
    5-Speed Transmission
    I have a lot more invested than this, that's with using all the connections. If interested in more details please PM. Not interested in trades. Thanks
