Solid axle, with or without holes
Discussion in 'The Hokey Ass Message Board' started by rods&cycles, May 24, 2013.
  1. rods&cycles
    rods&cycles
    from Iowa
    Just getting ready to purchase a forged dropped axle from So-Cal for my '29 coupe project.
    The question is which would you buy, with or without holes? It's a puzzler!
    :confused:
  2. Mr48chev
    I've got one of their axles with no holes but it's going under a car with fenders. Do what ever you like as they are a serious heavy duty unit.
  3. badshifter
    badshifter
    Since you asked what I'd buy, an original Ford axle, dropped.
  4. rods&cycles
    rods&cycles
    from Iowa
    I should have mentioned that this will be a fenderless hi-boy
  5. HotRodHighley
    HotRodHighley
    from cincy, oh
    Holes..That's what i am putting on my fenderless hi-boy. I like the look..
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Holes for sure. :D
    Don
  7. Cruiser
    Cruiser
    Fender less go with the axle with the holes, axles with holes is traditional and as old as hot rods themselves. :D
    CRUISER :cool:
  8. Whats the cost split? Buy the plain one & drill it yourself
  9. Jcox68rt
    Jcox68rt
    Me likes me some speed holes!:cool:
  10. As long as it's forged you are OK with which ever one you pick. HRP
  11. Fogger
    Fogger
    I'd recommend one of two axles, either an original Ford or a Chassis Engineering, Inc made in West Branch, Iowa. Solid American made forged products. If you decide to drill holes it's no big deal just time consuming.
  12. 49ratfink
    49ratfink
    HOT RODS got holes.
  13. tfeverfred
    tfeverfred
    I'm looking to get one with holes this winter.
  14. Holes for the hole shot :)
  15. Without and drill them yourself so you can make the layout however looks good to you.
  16. gnichols
    gnichols
    from Tampa, FL
    I wonder exactly how many ounces you can actually remove from a beam axle by drilling a bunch of holes? Anyone save the waste and weigh it before? Then there's the strength versus pot hole factor.
    Looks aren't everything. A drilled axle sure is cool looking, but an "8" that's up is far better than a "10" that's hard down any day. And bugs are easier to remove from a chromed tube axle, IMHO. Gary
  17. triumph 1
    triumph 1
    I would get the one with holes in it.
  18. Dan Timberlake
    Dan Timberlake
  19. F-6Garagerat
    F-6Garagerat
    Yep. 296V8 here on the HAMB has done 3 for us. Just looks right IMO.
    http://www.jalopyjournal.com/forum/showthread.php?t=614475
    Fixed a 32 heavy for my brother. Had bad spring shackle wear on top of the axle, it was bent too. My brother told Greg he just wanted it to look like a nice stock axle. Not only did he fill the wear marks and the bend and the camber, he put the forging parting line back in on the top of the axle!! Great work.
  20. Kirk Hanning
    Kirk Hanning
    I drilled an axle with (12) 7/8 holes. It's been awhile but if memory serves me correct it saved about 2 pounds on the axle.
  21. tommy
    tommy
    Today it's more of a decorative thing than weight savings. That's how it started but do you really care about 2 Lbs? I'm an 'original parts snob." I dislike reproduction parts that can be identified as reproduction from 20 feet. JMHO What is the cost of buying a Henry dropped axle? If it is close it's a no-brainer for me. I drilled my first dropped beam axle when everybody else was buying Superbell tube axles 40 years ago.
  22. 1971BB427
    1971BB427
    from Oregon
    Holes if it shows!
  23. bgaro
    bgaro
    ford w/holes
  24. Blue One
    Blue One
    from Alberta
    I looked at the price of the So-Cal axle with the holes, and without.
    I said hell for that many $ I can drill my own holes :)
    So I bought the undrilled version and did so. Details are on my 26 RPU build thread.
  25. I like holes but I have seen them without holes that I like just as well. From an engineering standpoint it is really six of one or half a dozen of the other, it will not make any difference in the operational strength or not enough to make any difference that you will ever notice. So it just comes down to what you prefer.
  26. tfeverfred
    tfeverfred
    Has anyone ever filled the holes with coins or brass plugs? I wonder how that would look?
  27. ratrod0
    ratrod0
    Holes for me
  28. elmitcheristo
    elmitcheristo
    As others have said, buy the plain axle and drill it to your own preference. I like my old Ford parts, but the new forgings are hard to beat for the price. The last 4 or 5 old Ford drop axles that I have picked up were worn, bent, or just plain ugly. If I wanted to have an original axle that had been dropped, I would bypass the swap meets and just use on of the vendors that advertise on here. It seems as they have lots of happy customers.
    My .02,
    Mitch
  29. BAD PENNY
    BAD PENNY
    from mass
    I hemmed and hawed over the same thing when I replaced the front end on my coupe. In the end I decided to go with the So-Cal one w/o holes since it's got fenders, but sometimes I wish I'd gone with the holes !!!???
    John 34 Ford likes this.
  30. telecaster_6
    telecaster_6
    I'm running a Chassis Engineering axle. Keep in mind...those suckers are THICK, probably 5/8" thick in the web. I did mine on a mill with a end mill carbide cutter and it still took me a good 2 hours.
