Technical Sombrero wheel cover
Discussion in 'The Hokey Ass Message Board' started by Speedys Garage, Dec 14, 2025.
  1. 20251213_162556[1].jpg 20251213_162445[1].jpg I have several of these 1953 Cadillac Sombrero type wheel covers - could someone tell me how to attach these to the wheel - I think these are 15 in. measure 15 1/2 across - shown picture of front and back
    thanks in advance - Speedy
  2. K13
    K13
    Those usually require the corresponding '53 Cadillac wheel. They are too deep to fit on a regular wheel.
    Dave Mc and Moriarity like this.
  3. THANK YOU I will check this
  4. lostn51
    lostn51
    from Tennessee
    I’ve seen them with trim rings soldered or welded to them so they fit regular wheels. But like stated they need to be a little deeper than normal for the dish.
    Dave Mc likes this.
  5. I have been told this in the past was just intrested how work on stock wheel thank you
  6. Mr48chev
    59/54 at least Caddy wheels were pretty deep to get those caps to fit and had the special center with clips that held the cap. bolt pattern is 5 on 5. Pontiac used a similar setup but I don't know if the wheels are the same.
    The red wheels are a set that Marty4-0 posted in the cl***ifieds a few years ago are 56 wheels Screenshot (2266).png IMG_20210417_125041.jpg
  7. I cut the center out and tack weld 15 in beauty ring to the outer edge and they went right on regular rims
    drdave and Speedys Garage like this.
  8. thanks this is probably what I will do
  9. thanks for the info I have a set of 56 wheels
