some help need with finned valve covers
Discussion in 'The Hokey Ass Message Board' started by InsaneEmpire909, Sep 15, 2009.
  1. InsaneEmpire909
    InsaneEmpire909
    from 909
    Ok guys, last night I put my intake on my 350, its a old school edelbrock that has a oil fill tube. I had purchachase some new cal customs finned valve covers from mooneyes a while back. well now thhe valve covers hit the intake? its only the drip edge of the valve cover and not the actual mating surface for the gasket. any sugestions? should I take some material off the intake or the valve covers? Heres a picture of the covers and where they are rubbing. Please help! thanks
  2. 327-365hp
    327-365hp
    from Mass
    Take a little off the valve cover. Original corvette ones are notched.
  3. 57 HEAP
    57 HEAP
    Are there cut out already in the valve cover on the other side? I have some LT-1's that chevy cast with a flat in the area you are speaking of, but only on one side of the valve cover.
  4. InsaneEmpire909
    InsaneEmpire909
    from 909
    no flat areas, they both have that little bit of overhang
  5. Von Dago
    Von Dago
    from New Jersey
    Is the gasket in there yet?
    A thick cork gasket might make a difference.
  6. InsaneEmpire909
    InsaneEmpire909
    from 909
    its at least a 3/8 gap between the covers and the mating surface for the head
  7. paintcan54
    paintcan54
    I have the same covers on my car I took and marked where I needed to cut the edge and took a little off at a time till I got them to fit. Just remember to clean out the gringings every time you set them back on to check the fit, when all done wash them out good luck.
  8. InsaneEmpire909
    InsaneEmpire909
    from 909
    thanks guys for the info.
  9. DE SOTO
    DE SOTO
    Don't ya Just LOVE the Quality of the new CHINESE Moon Junk they sell ?
    Relieve the Covers a bit like the others said, I have had a few Old sets that were already relieved for clearance from the Factory.
  10. chevyshack
    chevyshack
    I dont think this has to do with chinese junk. Its a performance intake ment to run with performance valve covers. Id try running thicker gaskets before i went grinding away at the valve covers.
  11. hot rod pro
    hot rod pro
    from spring tx.
    i would think they would be made in japan,since they own moon.
    -danny
  12. SimonSez
    SimonSez
    I had the same problem with some sand-cast Edelbrock covers and an old Weiand intake. I found some thick cork valve cover gaskets (made by Detroit Gasket, I think), and they raised them enough to clear without grinding.
  13. redlinetoys
    redlinetoys
    from Midwest
    I would HATE to cut those valve covers. I think you could easily relieve the intake a little to make them work in conjunction with some Mr Gasket thick cork valve covers (They make them in thicknesses near double the norm.)
    Let us know how you end up either way.
  14. InsaneEmpire909
    InsaneEmpire909
    from 909
    already tried that. unless I stack 2 gaskets (which I wont even consider) it wont work still
  15. DE SOTO
    DE SOTO
    HMMM,
    So what is the difference with a so called "PERFORMANCE VALVE COVER" ?
    NO KIDDING ?
    I was Poking fun at MOON since they are owned by the Japanese
    You would HATE to cut those Brand New Off Shore MOON covers, But your Willing to Cut on a Vintage Intake Manifold ?
  16. InsaneEmpire909
    InsaneEmpire909
    from 909
    ok so this ****ed, I ended up taking about 3/8 off the intake via grinder. then had to take and notch the covers. I am just **** and didnt want gaskets showing. thanks
