some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. Okie Pete
    Okie Pete
    Amazing skills , Thanks for showing what you do in your shop.
  2. cornfieldcustoms
    cornfieldcustoms
    finally got a pic of the rear fender i made installed on the truck. turned out pretty good. made on the power hammer in 2 pieces
  3. YJ4000
    YJ4000
    Amazing! As said before great work.
    Ryan.
  4. RebelAlliance
    RebelAlliance
    Wow just amazing.
  5. oldsjoe
    oldsjoe
    Looks to fit like a glove Mike. Super work! Joe
  6. 383deuce
    383deuce
    WOW IS ABOUT ALL I CAN SAY.
  7. rcnut223
    rcnut223
    from wisconsin
    Sick...
    no one should have that kind of skills:D
    bengeltiger likes this.
  8. cornfieldcustoms
    cornfieldcustoms
    here are some pics of what i am working on this week. fiat topolino sheet metal repair. started by making the p*** lower 1/4 / dog leg panel. made in 1 piece, just one weld seam. i slit the inner area at the bottom rocker union, formed the radius then tig welded the seam back up. should have more progress on this one in the near future. need to make a new cowl area, spare tire well and the driver side lower 1/4 patch
    rcnut223, wedjim, Stogy and 5 others like this.
  9. oldsjoe
    oldsjoe
    More good work from Cornfield! Joe
  10. MP&C
    MP&C
    Nice work Mike!
  11. cornfieldcustoms
    cornfieldcustoms
    a little more progress on the anglia
    started to pattern whats left of the spare tire well on the rear.
    transferred to a 37 inch 18 gauge steel disk
    after the first set of shrinks on the power hammer
    quick p*** on the hammer with the plannishing dies
    then back to shrinking to start pulling up the lip to meet the rear of the body
    still a long way to go, but only got an hour to put in on this part before i headed home from the shop
    loudbang, Stogy, kiwijeff and 3 others like this.
  12. oldsjoe
    oldsjoe
    That's a lot of progress in an hour if you ask me! Going to be cool Mike! Joe
  13. AHotRod
    AHotRod
    I have learned so much following along with you on this thread for the last 5 years.... and on Facebook. Thank You for sharing your talents with us.
  14. cornfieldcustoms
    cornfieldcustoms
    got the spare tire well all shaped up, still some fine tuning and plannishing to do before it is 100% but looks good so far.
    loudbang, 54reno, Stogy and 6 others like this.
  15. wedjim
    wedjim
    from Kissimmee
    Damn fine work! I wouldn't attempt it myself, I'd pay you instead after seeing this thread.
  16. Bugguts
    Bugguts
    Wow! That spare tire well is awesome. Definitely takes a good understanding of sheet metal and how it reacts to produce that. Nice.
    clem likes this.
  17. oldsjoe
    oldsjoe
    So the question is which came first the tire or the well! Nice work Mike! Have a great Easter. Joe
  18. Always a pleasure to check in here.
  19. i.rant
    i.rant
    Top notch craftsmanship, thanks for sharing.
  20. YJ4000
    YJ4000
    Great! I agree with Bugguts.
    Ryan
  21. Incredible metal work, Fantastic.
  22. bengeltiger
    bengeltiger
    Always a treat to see what you're working on. Also enjoying your YouTube videos! Thanks for taking the time.
  23. Stogy
    Stogy
    Rust and damage just runs away when it sees you coming...it is no match. Stellar craftsmanship Mike. Thanks for sharing. Incredible to watch the transformations. In wounded...Out happier than a pig in...;)
  24. rcnut223
    rcnut223
    from wisconsin
    Could you share how you made the inner lip in this?
    Thanks
    Mike
  25. cornfieldcustoms
    cornfieldcustoms
    it will be tough to explain via text, instead of in person or a video. but here it i goes, from the flat surface of the lower 1/4 to go inward for the first part of the inner lip area is all stretch. so you lay out the shape of the curve on the panel, then begin to linear stretch the lip over. after that you will have a curved 90* on the radius of the door jamb. then you need to bring part of that lip back up to begin to make the J shape that goes in the door opening. so since you linear stretched to get the first 90, you need to shrink back the edge to get it back to a 90 back in the other direction. in this case i used a kick shrinker. so after some shrinking you have a Joggle or Z shaped panel. you get the last part brought over again to finish the J shape. since the lips are getting smaller each time since you are moving the lines you are working on outward it is hard to use power equipment on them. so the step of making the J is more stretch, i used kick stretcher to work that back out. there is some fine tuning to that will need done, i use home made T dollies to do that and a body hammer. i hope that helps. if i not i can make another one for demonstration purposes and show the steps
    bengeltiger and loudbang like this.
  26. cornfieldcustoms
    cornfieldcustoms
    started making a 37 ford deck lid skin for a customer car. hope to have it finished up tomorrow
    making paper patterns
    test fitting shape of the new skin to the body, it fits very nice, only need to lightly push in bottom of the skin with 1 finger
    doing the final trim before i start to turn the edge for the hem edge
    pcbart, 1952B3b23, 54reno and 2 others like this.
  27. 34toddster
    34toddster
    from Missouri
    Did you only use the English wheel on this panel?
    thanks. Looks very nice!
  28. cornfieldcustoms
    cornfieldcustoms
    99 percent of the work on this skin was on the wheel. we did use the power hammer a little to just raise up a weird spot that developed in one spot. but everything else was done in the wheel
    hem edges turned, ready to put the inner lid in the skin
    pretty much all ****oned up
    also been working on a roll cage for a local customer for his land speed blown flat head 29 roadster
    still a ways to go on the cage but it is getting there one tube at a time
  29. oldsjoe
    oldsjoe
    Your moving them in and out pretty quickly Mike and the quality is always top notch! Joe
  30. Bandit Billy
    Bandit Billy
    I have got to remember to not open this thread. Every time I think I have developed some metal talents I see these pictures and realize I am a complete hack. ****, and I was having a good night till now.
    Magnificent work sir.
    JOYFLEA, Bam.inc and loudbang like this.
