Some pics of my flathead with intake and heads
Discussion in 'The Hokey Ass Message Board' started by myke, Apr 12, 2007.
  1. myke
    myke
    from SoCal
    Well the engine is just about done. I brought my intake down to the machine shop for some pics.
    Got to love the NOS Evans heads!
    Engine specs:
    merc crank
    3 5/16" bore
    ross pistons
    literio L100 cam
    Balanced
    Lightened flywheel
    9.0 to 1 compression (based on a 61 cc chamber with a light relief)
    Light porting job exhaust and intake
    Evans intake with 3 81's
    I have a harmon collins dual coil ignition for it. I am using a early 3 speed and a columbia rear with 3:78 gears.
    Should be fun, I can't wait to here it run. I am going to run straight 1 3/4" pipes to the rear of the car.
  2. THOMAS S&C
    THOMAS S&C
  3. fast_46
    fast_46
    Beautiful.....what's it goin' in?
  4. ROBERT JAM
    ROBERT JAM
    where did you come up with those heads.Very nice,Flatheads are just beautiful
  5. myke
    myke
    from SoCal
    The motor is going in a 32 coupe.
    I made some calls and found someone that had 2 NOS sets and he was willing to sell me one of them.
  6. j ripper
    j ripper
    from napa ca.
    4 5/16. now thats what i call a big bore... haha
  7. class 'A'
    class 'A'
    from Casper,Wyo
    Bitchin!! oh yea and MMMM........Columbia Rear!!! Nice find! This being backed by a '39 box with a Zephyr set?
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    You mean Evans was the only company that made heads just like the modern ones with larger water jackets since they all use the long studs rather than replacing the original iron heads with no modification???? And no one picked up on it until the last 10 years or so??
    I 'm sorry, I think those are new production heads, not NOS.
    Great engine no matter what!!
  9. Cshabang
    Cshabang
    man is that purdy.....
  10. flatoz
    flatoz
    love flatheads. hope to have mine back together really soon.
  11. strombergs97
    strombergs97
    Hello..Looks great..With three 81s, thats 405 CFMs with full linkage..Should run great, maybe a little lean..
    Duane..
  12. Muttley
    Muttley
    Where did you manage to find the scoops? I have one and have been looking for two more for three+ years with no luck.
  13. LowFat48
    LowFat48
    wow , thats nice...
  14. 40SLOPER
    40SLOPER
    looks great. like how you did the engine stand too
  15. A4ord
    A4ord
    Thats a neat little? flatmotor,but 4 5/16" bore is one big flathead.The valves worked out at 2 1/8" as well.so we're looking at around 400 cubes.In that case them 81's might be a bit small. Anyway let us know how it runs. Those heads are nice and clean for NOS as well. Really just 3 5/16" Isn't it? Keep up the good work.
  16. myke
    myke
    from SoCal
    Those heads have standard water jackets....those studs I am using are just the standard length that you get from speedway. Not sure what you were looking at?
    So everyone that has 2 97's (310 cfm) runs lean? Based on this cfm calculator I have too much carb:
    total cfm = (rpm)(CID) divided by 3456 For an example I'll assume the max rpm you'll turn this is 3800. Your engine will have 276 cubes. Then: cfm =(3800)(276) divided by 3456 = 303 cfm. This is what I'd recommend for the street.
    Taken from here:
    http://www.btc-bci.com/~billben/flathead.htm
    http://www.btc-bci.com/~billben/intake.htm
  17. myke
    myke
    from SoCal
    Yes 3 5/16", I wish it was 4 5/16"
    I thought the heads were too clean also...but you can see how different the old aluminium looks is compared to new aluminium. Just not as good quality, now I understand why it was so hard to weld up another set I have.
    Thanks for the comments!
  18. Cadien
    Cadien
    Guy said 3 5/16 in his post. Re Read it.
  19. SUHRsc
    SUHRsc
    gona be on the road in no time!!
  20. AV8Paul
    AV8Paul
    You're going to love the sound of that literio L-100 cam. I have one in my AV8 and it sounds wicked.
  21. What valves and valve sizes are you running? Looks like 1.6 in the intake - is exhaust 1.5?
    Dale
  22. uncle max
    uncle max
    Who cobbled together those cheesy 81's? :D
  23. pasadenahotrod
    pasadenahotrod
    from Texas
    Modern production of the old brand name hotrod heads are made with a flat head(no pun intended) and all studs are equal length. This increases the water jacket capacity, requires the replacement of studs on an old engine, and also "cleans up" the heads appearance since they don't have the stud pockets like factory heads and original production speed heads do.
    Original speed heads were made as direct replacements for stock Ford/Merc iron heads and thus have the stud pockets in the top of the heads to accomodate the varied stud lengths used to hold down stock heads.
  24. tjm73
    tjm73
    I am pretty sure that formula needs to have it's result multiplied by the volumetric efficency (.80 if an engien is 80% volumetricly efficent) of the engine the carb would be installed and run on.
    Flatheads have a realitively low VE%.
  25. Flat Ernie
    Flat Ernie
    Tech Editor
    Personally, I think the carb cfm calculators are a bit overrated & tend to come out the small side. In addition to that, the carbs aren't all rated the same, so you're comparing apples to oranges to watermelons - a 600 cfm Holley does NOT flow the same as a 600 cfm Edelbrock.
    An engine will pull only what it needs - the potential downside to using too large (or too many) carb(s) is that you weaken the signal to the venturi...hurts throttle response, but if jetted/tuned correctly, won't
    FWIW - I recently watched a bone stock (well, it had center dump headers for the dyno) 239/100hp flatty do several dyno pulls with straight-linkage 3x2 running stock rebuilt 97s - it ran fine if ever so slightly rich for the altitude it was at - a reject to .043 jets would probably have cleaned it right up.
    Picked up about 11HP over a stock single-carb intake, but was down slightly at lower RPMs.
  26. tjm73
    tjm73
    So how much horsepower and torque did it make????? :)
  27. Flat Ernie
    Flat Ernie
    Tech Editor
    Stock was 96 & with the 3x2 it was 107 - don't know what it corrects to for sea level & standard day (heck, it may have been corrected already by the dyno) - where the dyno is is right at 5300ft...
  28. tjm73
    tjm73
    So that 100 hp rating from way back when was pretty close.
    Probably get better as the engine breaks in.
  29. Love the motor but its kind of funny how Einsteinish its sounding in here with all the calculations,some people cant just be happy for another mans success.
  30. myke
    myke
    from SoCal
    My valves are just stock sized stainless steel.
    Do note that the carbs were expertly rebuilt by uncle max here on the HAMB. Better than excellent service.
    I also can't say enough good about Ted Wingate (Precision Balancing) who did all the machine work/assembly and put up with all my issues putting it together.
    The manifold was also tumble polished by warbozz. It came out excellent and he has great service also.
