Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. biggeorge
    biggeorge
    [​IMG][​IMG]
    I've made it a couple times and my grandson enjoys himself. Always impressed with the guys that let the younger generation sit in their cars.
  2. wheeldog57
    wheeldog57
    biggeorge likes this.
  3. BenLeBlanc
    BenLeBlanc
    What is the pines reunion? I could potentially show
  4. Like I said I only have 57-64 Chevy rear parts.
    wheeldog57 likes this.
  5. biggeorge
    biggeorge
    I could say right where they raced but then I'd just be another a hole from Chelmsford.
    It's at the high school in Groveland right on 113 just after you cross the merrimac river leaving Haverhill. About halve an hour from Chelmsford.
    BenLeBlanc likes this.
  6. 32 hudson
    32 hudson
    Pines Speedway Annual Reunion 2017 In Groveland , Ma I can not find the exact date.
  7. biggeorge
    biggeorge
    First sat. In October. It's the 7th this year . I love noon time when they fire them all up !
  8. wheeldog57
    wheeldog57
    Racecar and old car show at former oval track in Groveland, Ma. Yes Ben, bring your car over and we can roll in together
    Sent from my SM-G930V using The H.A.M.B. mobile app
  9. wheeldog57
    wheeldog57
    Been venturing out and about last few days. Pretty sure I have a couple fouled plugs but, I must say, it drives great.
    Today I tested the brakes by hitting the pedal hard. I broke the linkage where it was welded.
    A slow, safe return trip home was achieved. WHEW![​IMG]
    Tim, clunker, patmanta and 4 others like this.
  10. BenLeBlanc
    BenLeBlanc
    You got a pic of the failure?? Would bed good for me to check on mine...
  11. wheeldog57
    wheeldog57
    No pic. Arm broke off from the "sleeve" portion of the pedal****embly. I had welded, then re-welded it. A simple case of too much weld-not enough original material. Haha, now I have to re- check all my welds. YAY!
  12. BenLeBlanc
    BenLeBlanc
    That's what makes me nervous though, as the real problem is that the pedal is forged I think. You have to weld forged metal with a lot of heat- make a small pass to heat it up, and then a huge pass to stick it for sure. Or at least that is what I was told. Makes me want to make sure my e brake works. Haha
  13. sloppy jalopies
    sloppy jalopies
    I heated the 3/4" pedal shaft red hot, it welded up nice... I had also ground a 1/2" offset into the two shaft ends first....
    wheeldog57, BenLeBlanc and biggeorge like this.
  14. wheeldog57
    wheeldog57
    tb33anda3rd, Jet96, 28rp and 11 others like this.
  15. BenLeBlanc
    BenLeBlanc
    Love the stance of the car...
    wheeldog57 and biggeorge like this.
  16. wheeldog57
    wheeldog57
    Took the brake pedal****embly apart and heated it up then slammed some mig welds onto it. Raining here today so no test drive. Folded up some stainless over the plywood floor.[​IMG][​IMG]I will probably regret using the stainless, going to be "blinded by the light, revved up like a duece another runner in the night. . . ."
  17. biggeorge
    biggeorge
    It's really looking great.
    are you going to take it to the pines on Sat?
    George
  18. wheeldog57
    wheeldog57
  19. biggeorge
    biggeorge
    Nice I'll be looking for it.
    wheeldog57 and BenLeBlanc like this.
  20. Crusty Chevy
    Crusty Chevy
    Might be slippery too, try some skateboard deck traction tape or stair tread texture paint.
    BenLeBlanc, biggeorge and wheeldog57 like this.
  21. wheeldog57
    wheeldog57
    A rare picture of Mike Bowling. He made a nice driveway line up today[​IMG][​IMG]
  22. wheeldog57
    wheeldog57
    The tree is a cucumber magnolia, quite a specimen if I may say.
    biggeorge, lowroller1 and BenLeBlanc like this.
  23. Nailhead A-V8
    Nailhead A-V8
    way to go Wheeldog! my eventual goal is a driveway like yours....
  24. biggeorge
    biggeorge
    I would love a tree like that in my yard!!
  25. wheeldog57
    wheeldog57
    Have been fooling around with windshield posts. . . Got a pair of Model T stanchions at the swap meet for $20.00. Cut and welded until they looked cool.[​IMG][​IMG][​IMG][​IMG]still need some more work but I think they look ok.
  26. wheeldog57
    wheeldog57
  27. biggeorge
    biggeorge
    You are now a fabricator.
    Welcome to the world that say's I can do that and save [emoji857][emoji857].
    By the way that is a great idea and they look fantastic.
  28. sloppy jalopies
    sloppy jalopies
    Inside the box, what box... he can't even see the box... go WD57 go...
    for hot rodders who are looking out through holes in the box...
    try using the front 14" or so of a pair of ford rear wishbones...
    you can use the front bolt holes to look like top anchors....
    made a pair of '30 roadster upper stations out of them ... worked good.
    best part is they are gonna be cheap !
    now back to your regularly scheduled post.
  29. BenLeBlanc
    BenLeBlanc
    Love the angle! Are you going to chop them shorter, or leave them long? You’re height probably needs them long!
  30. wheeldog57
    wheeldog57
    A lot of thought went into these before they were chopped up. I made up a windshield frame out of scrap 3/4 tubing . I made it just tall enough for me and the stanchions were made to fit the frame. The set up is somewhere between stock height and the "deluxe".
    Besides, now I can brag about making my own windshield!
