Projects Sometimes you just need a break!
Discussion in 'Traditional Hot Rods' started by oj, Mar 15, 2019.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
  2. Dino 64
    Dino 64
    from Virginia
    Lookin good OJ !!
    oj and lothiandon1940 like this.
  3. Jalopy Joker
    Jalopy Joker
    Interesting set up - would be nice to be able to see spring pack
    RICH B likes this.
  4. oj
    oj
    I have a feeling I'll be able to show it to you, sad to say. I have this need to inflict a little more pain on myself, just not today. There's something unsettling about taking a spring pack apart, you are 'a bizarre accident' away from a coma. Know what I mean?
    Dino 64 and lothiandon1940 like this.
  5. lothiandon1940
    lothiandon1940
    ...........Exactly. Be very careful.
    Dino 64 likes this.
  6. RICH B
    RICH B
    Since "too low" was due to oil pan to ground clearance; was "too high" based on relationship to rear end height?
    Your front end is kind of an unusual combination of parts; will be interesting on how you work this out.
  7. gene-koning
    gene-koning
    You could solve all this mess by sitting on your chair watching TV like 80% of the rest of America.
    Or you step up to the problem and try something different. I'm pretty impressed by how many people can solve some of these problems in three tries! Three or 4 tries are usually my first design. Some stuff on my truck project are on the 4th or 5th design. Some times you just have to walk away and try something different the next time.
    Success is when you whip the problem and can move on to the next thing on the list. Like said earlier, if it was easy, everyone would have a cool ride. If everything was easy, there wouldn't be as much satisfaction in the completed project. Gene
    oj and TrailerTrashToo like this.
  8. oj
    oj
    Well, here it is, 9 leaves, the bottom two look fatter because that how much vynl left over from doing the rear elipticals. 006b.JPG
  9. oj
    oj
    Model 'A' front axle done by Okie Joe, square back spindle, '56 Buick backing plate, '37 Ford wide5 hub, Finned Buick drums not yet joined to the hub - I had lots of help from **** Spadaro (we miss ya ****!), lower steering arms flipped and swapped to get tie rod above the frame, cowl steering. Normal HotRod stuff.
  10. oj
    oj
    Well, here it is back together. I unreversed the main leaf, here's my spreader bar ( I felt like Wile E. Coyote jumping up and down on the failed trip wire after the RoadRunner p***ed by as I tightened the nuts).
    About 4" under the oil pan, tight on the tie rod clearance but I can 001 (3).JPG 003 (2).JPG 002 (2).JPG deal with that.
    Dino 64 likes this.
  11. Dino 64
    Dino 64
    from Virginia
    Beep Beep !
    oj likes this.
  12. Jalopy Joker
    Jalopy Joker
    good that you got things the way that you want them to look - proof will be in the ride
    oj likes this.
