Technical Sonic Testing - Three Flathead Blocks - All bored 3 3/8!
Discussion in 'Traditional Hot Rods' started by Bored&Stroked, Jan 15, 2015.
  1. I have a Dakota Digital PR-8 . . . with probes for cylinders as well as ports (3 different ones). The base system is about $1200, which is not cheap, but when you deal with a lot of early blocks and consider the time/money spent on bad results . . . kind of makes sense. The other reason I have it is due to porting flathead blocks (Flathead Cadillac, Ford V8) - these things give you some idea as to what material you have to work with inside of a port or around the valve pocket and they definitely make it possible to sleep at night!
    Once you have one . . . you'll always have one . . .
    Dale
