SOS 53 belair v8 and rear end (differential)
Discussion in 'The Hokey Ass Message Board' started by old53chevy, Dec 26, 2008.
  1. old53chevy
    old53chevy
    I am swaping out my drivetrain on my 53chevy belair. I have the 327 and 700r ready to go in but i don't have a rear end. I yet to deal with the rear end so am i navagating new water (no clue on rear ends). Does any one know if there are any rear ends that can bolt in place or need few modification. I am looking for ideas, blogs or picture of someone that has done it.
    So far i have hear 55-57 chevy bolt on and 71-80 camaro fits with some work.???
  2. oilslinger53
    oilslinger53
    from covina CA
    4x4 blazer rears fit , so i hear. those can be had fairly cheap, and are available at any junkyard
  3. I'll 2nd the S10/ Blazer 4X4 rear. Easy to find and a good variety of gear ratios too. Todd
  4. Ebbsspeed
    Ebbsspeed
    Yes, and many of those 4X4 rears will have a positraction diff.....
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    A 68-74 V8 Nova rearend will be an easy install in your 50s Chevy.
  6. old dirt tracker
    old dirt tracker
    from phoenix
    a main consideration is the correct ratio to go with the 700 tranny. depending on tire size i would guess something around 3.50.
  7. Terry
    Terry
    I am currently swapping mine. right now it has a 75 Camaro which is 61 1/2 wide. I'm running 15X7 rims with 4 1/2 backspace.
    The new rear end is a 64 Chevelle and is 60 inches wide. Then I will be able to move to a 15X8 with a 5 inch backspace to get some wider rubber underneath.
    As far a bolt in, no. I using the rear end mount kit from Chassis engineering.
  8. old53chevy
    old53chevy
    hey terry how do you get the measurement of 61 1/2?? from what points are you measuring from?? Do you have any picture of the rearend of your car?? Didi you use Chassis engineering kit (part AS-1021CC)??
  9. Terry
    Terry
    Outside to outside of drum, right where the wheel meets the drums. Thats the kit but it isn't installed yet.
